Ana içeriğe geç
Asus ROG G750JM-BS17N23 Hard Drive Replacement
Neye ihtiyacın var
  1. Asus ROG G750JM-BS17N23 Hard Drive Replacement, Back Plate: adım 1, 1 resimden 1.
    • With the computer upside down, lift up on the rubber cap on the back plate to access the captive Phillips #2 screw.
  2. Asus ROG G750JM-BS17N23 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Retract the Phillips #2 screw until the cover is loose.
    • The screw will not come all the way out.
  3. Asus ROG G750JM-BS17N23 Hard Drive Replacement: adım 3, 3 resimden 1. Asus ROG G750JM-BS17N23 Hard Drive Replacement: adım 3, 3 resimden 2. Asus ROG G750JM-BS17N23 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Pry around the edges of the plate using a plastic opening tool until the plate is removed.
  4. Asus ROG G750JM-BS17N23 Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • To access the hard drive, remove the back plate.
  5. Asus ROG G750JM-BS17N23 Hard Drive Replacement: adım 5, 2 resimden 1. Asus ROG G750JM-BS17N23 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Remove the three 4mm Phillips #2 screws.
  6. Asus ROG G750JM-BS17N23 Hard Drive Replacement: adım 6, 2 resimden 1. Asus ROG G750JM-BS17N23 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Pull back on the tab on the hard drive shield until it is clear of the screw slots. Next pull the shield out.
  7. Asus ROG G750JM-BS17N23 Hard Drive Replacement: adım 7, 2 resimden 1. Asus ROG G750JM-BS17N23 Hard Drive Replacement: adım 7, 2 resimden 2.
    • With the hard drive exposed, pull the hard drive away from the connection point and then remove the hard drive.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 470
