Ana içeriğe geç
Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement
Neye ihtiyacın var
  1. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement, Soundbar/speaker: adım 1, 2 resimden 1. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement, Soundbar/speaker: adım 1, 2 resimden 2.
    • Using a plastic opening tool, remove the two rubber tabs circled in red.
  2. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: adım 2, 2 resimden 1. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: adım 2, 2 resimden 2.
    • Remove both of the 8mm Phillips #2 screws from these slots where the rubber caps were removed.
  3. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: adım 3, 2 resimden 1. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: adım 3, 2 resimden 2.
    • Slide the tab to pop the battery out of its holder.
    • Pull the battery out of its slot.
  4. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: adım 4, 2 resimden 1. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: adım 4, 2 resimden 2.
    • Remove the three 4mm Phillips #2 screws from the open battery slot as shown.
    • Remove the two 5mm Phillips #2 screws.
  5. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: adım 5, 3 resimden 1. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: adım 5, 3 resimden 2. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: adım 5, 3 resimden 3.
    • Begin prying up on the plate as shown in the pictures.
  6. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: adım 6, 1 resimden 1.
    • Detach the single connector using your plastic opening tool.
    • Remove the speaker bar.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 389
