Ana içeriğe geç
Asus ROG G751JL-BSI7T28 Display Assembly Replacement
Neye ihtiyacın var
  1. Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Back Panel: adım 1, 1 resimden 1.
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: adım 2, 3 resimden 1. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: adım 2, 3 resimden 2. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: adım 2, 3 resimden 3.
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Display Assembly: adım 3, 2 resimden 1. Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Display Assembly: adım 3, 2 resimden 2.
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: adım 4, 2 resimden 1. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: adım 4, 2 resimden 2.
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: adım 5, 3 resimden 1. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: adım 5, 3 resimden 2. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: adım 5, 3 resimden 3.
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: adım 6, 3 resimden 1. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: adım 6, 3 resimden 2. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: adım 6, 3 resimden 3.
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: adım 7, 2 resimden 1. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: adım 7, 2 resimden 2.
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
Sonuç
Kristen Gismondi
81.754 İtibar
200 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.767 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 339
