Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
With the laptop closed, turn it upside-down so the bottom is facing up toward you.
Place a spudger into the notch, and pry the small triangular piece away from the laptop.
Using a Phillips #00 screwdriver, remove the single 3 mm screw.
Place a spudger beneath the back panel and pry it away from the laptop.
Remove all 5mm Phillips #00 screws from the back cover.
Use a spudger to pry the disc drive out of the laptop.
Open the laptop and turn it so that the ASUS logo is facing you.
Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
Remove the 5mm Phillips #00 screws.
Lift up the silver hinge brackets on each side of the laptop.
Remove the 5mm Phillips #00 screws from the hinges.
Detach the ribbon cable and remove the display assembly from the laptop.
Carefully lift the keyboard up, being careful to not damage the fragile ribbon connectors.
Use an opening tool to detach the ribbon cables connecting the keyboard to the rest of the laptop.
Remove the keyboard from the laptop.
Remove the fan's power cable by pulling carefully outward towards the fan.
Remove the 5mm Phillips #00 screw.
Pull up on the black tab connected to the fan. This will pull it away from the cooling fins, allowing it to be removed.
Remove the fan from the laptop.
