Ana içeriğe geç
Asus ROG G751JL-BSI7T28 Speaker Replacement
Neye ihtiyacın var
  1. Asus ROG G751JL-BSI7T28 Speaker Replacement, Back Panel: adım 1, 1 resimden 1.
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 2, 3 resimden 1. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 2, 3 resimden 2. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 2, 3 resimden 3.
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 Speaker Replacement, Display Assembly: adım 3, 2 resimden 1. Asus ROG G751JL-BSI7T28 Speaker Replacement, Display Assembly: adım 3, 2 resimden 2.
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 4, 2 resimden 1. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 4, 2 resimden 2.
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 5, 3 resimden 1. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 5, 3 resimden 2. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 5, 3 resimden 3.
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 6, 3 resimden 1. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 6, 3 resimden 2. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 6, 3 resimden 3.
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 7, 2 resimden 1. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 7, 2 resimden 2.
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
  8. Asus ROG G751JL-BSI7T28 Speaker Replacement, Keyboard Assembly: adım 8, 2 resimden 1. Asus ROG G751JL-BSI7T28 Speaker Replacement, Keyboard Assembly: adım 8, 2 resimden 2.
    • Carefully lift the keyboard up, being careful to not damage the fragile ribbon connectors.
    • Use an opening tool to detach the ribbon cables connecting the keyboard to the rest of the laptop.
    • Remove the keyboard from the laptop.
  9. Asus ROG G751JL-BSI7T28 Speaker Replacement, Speaker: adım 9, 2 resimden 1. Asus ROG G751JL-BSI7T28 Speaker Replacement, Speaker: adım 9, 2 resimden 2.
    • Flip the SD card reader's retaining arm up.
    • Remove the SD card reader's power/data ribbon cable.
  10. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 10, 3 resimden 1. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 10, 3 resimden 2. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 10, 3 resimden 3.
    • Remove the speaker's power/data cable.
  11. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 11, 2 resimden 1. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 11, 2 resimden 2.
    • Remove four 3mm Phillips #0 screws from the speaker.
    • Remove three 3mm Phillips #0 screws from the SD card reader.
  12. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 12, 3 resimden 1. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 12, 3 resimden 2. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 12, 3 resimden 3.
    • Remove the SD card reader.
  13. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 13, 3 resimden 1. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 13, 3 resimden 2. Asus ROG G751JL-BSI7T28 Speaker Replacement: adım 13, 3 resimden 3.
    • Remove the speaker from the laptop.
Sonuç
Dylan Michael Leonard
423 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G1, Barthe Fall 2019 UMass Dartmouth, Team S1-G1, Barthe Fall 2019 üyesi
UMASSD-BARTHE-F19S1G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 215
