Ana içeriğe geç
Asus ROG G751JL-DS71 Fan Replacement
Neye ihtiyacın var
  1. Asus ROG G751JL-DS71 Fan Replacement, Fan: adım 1, 2 resimden 1. Asus ROG G751JL-DS71 Fan Replacement, Fan: adım 1, 2 resimden 2.
    • Lift the rubber cover found on the bottom of the laptop.
    • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
  2. Asus ROG G751JL-DS71 Fan Replacement: adım 2, 3 resimden 1. Asus ROG G751JL-DS71 Fan Replacement: adım 2, 3 resimden 2. Asus ROG G751JL-DS71 Fan Replacement: adım 2, 3 resimden 3.
    • Use the standard spudger to remove the back center panel.
  3. Asus ROG G751JL-DS71 Fan Replacement: adım 3, 3 resimden 1. Asus ROG G751JL-DS71 Fan Replacement: adım 3, 3 resimden 2. Asus ROG G751JL-DS71 Fan Replacement: adım 3, 3 resimden 3.
    • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
  4. Asus ROG G751JL-DS71 Fan Replacement: adım 4, 2 resimden 1. Asus ROG G751JL-DS71 Fan Replacement: adım 4, 2 resimden 2.
    • Pull out the optical drive found on the side of the laptop.
  5. Asus ROG G751JL-DS71 Fan Replacement: adım 5, 3 resimden 1. Asus ROG G751JL-DS71 Fan Replacement: adım 5, 3 resimden 2. Asus ROG G751JL-DS71 Fan Replacement: adım 5, 3 resimden 3.
    • Remove the screws holding the hard drives in place using a phillips #1 screwdriver.
    • Using the small flaps, remove the hard drives by hand.
  6. Asus ROG G751JL-DS71 Fan Replacement: adım 6, 2 resimden 1. Asus ROG G751JL-DS71 Fan Replacement: adım 6, 2 resimden 2.
    • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
  7. Asus ROG G751JL-DS71 Fan Replacement: adım 7, 2 resimden 1. Asus ROG G751JL-DS71 Fan Replacement: adım 7, 2 resimden 2.
    • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
  8. Asus ROG G751JL-DS71 Fan Replacement: adım 8, 3 resimden 1. Asus ROG G751JL-DS71 Fan Replacement: adım 8, 3 resimden 2. Asus ROG G751JL-DS71 Fan Replacement: adım 8, 3 resimden 3.
    • Use a metal spudger to carefully pry the top back panel off.
    • While removing the top back panel, be careful not to break the four pin connector located underneath.
    • Disconnect the four-pin connector and remove the top back panel from the computer.
  9. Asus ROG G751JL-DS71 Fan Replacement: adım 9, 1 resimden 1.
    • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
  10. Asus ROG G751JL-DS71 Fan Replacement: adım 10, 1 resimden 1.
    • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
  11. Asus ROG G751JL-DS71 Fan Replacement: adım 11, 3 resimden 1. Asus ROG G751JL-DS71 Fan Replacement: adım 11, 3 resimden 2. Asus ROG G751JL-DS71 Fan Replacement: adım 11, 3 resimden 3.
    • Use a metal opening tool to pry the keyboard from the base of the laptop.
    • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
  12. Asus ROG G751JL-DS71 Fan Replacement: adım 12, 2 resimden 1. Asus ROG G751JL-DS71 Fan Replacement: adım 12, 2 resimden 2.
    • Use a pair of tweezers to undo each of the four ribbon connectors.
    • The keyboard is now completely disconnected from the laptop and you can remove it.
  13. Asus ROG G751JL-DS71 Fan Replacement: adım 13, 3 resimden 1. Asus ROG G751JL-DS71 Fan Replacement: adım 13, 3 resimden 2. Asus ROG G751JL-DS71 Fan Replacement: adım 13, 3 resimden 3.
    • Disconnect the four-pin connectors from each fan and remove them
    • The fans are now completely disconnected from the laptop and you can remove them
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ashley Twigg
237 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S8-G8, Wilson Spring 2019 IUPUI, Team S8-G8, Wilson Spring 2019 üyesi
IUPUI-WILSON-S19S8G8
4 Üyeler
3 adet Kılavuz yazıldı
Bir Yorum
i was wondering if i can swap the bottom case of g751jl with bottom case of g751jy? thanks a ton
Avkash - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 971
