Ana içeriğe geç
Asus ROG G751JL-DS71 RAM Replacement
Neye ihtiyacın var
  1. Asus ROG G751JL-DS71 RAM Replacement, CD-ROM Player: adım 1, 2 resimden 1. Asus ROG G751JL-DS71 RAM Replacement, CD-ROM Player: adım 1, 2 resimden 2.
    • Lift the rubber cover found on the bottom of the laptop.
    • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Asus ROG G751JL-DS71 RAM Replacement: adım 2, 3 resimden 1. Asus ROG G751JL-DS71 RAM Replacement: adım 2, 3 resimden 2. Asus ROG G751JL-DS71 RAM Replacement: adım 2, 3 resimden 3.
    • Use the nylon spudger to remove the back center panel.
    FixBot'a Sor
    Yorum Ekle
  3. Asus ROG G751JL-DS71 RAM Replacement: adım 3, 2 resimden 1. Asus ROG G751JL-DS71 RAM Replacement: adım 3, 2 resimden 2.
    • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
    FixBot'a Sor
    Yorum Ekle
  4. Asus ROG G751JL-DS71 RAM Replacement: adım 4, 2 resimden 1. Asus ROG G751JL-DS71 RAM Replacement: adım 4, 2 resimden 2.
    • Pull out the optical drive found on the side of the laptop.
    FixBot'a Sor
    Yorum Ekle
  5. Asus ROG G751JL-DS71 RAM Replacement, Top Rear Panel: adım 5, 2 resimden 1. Asus ROG G751JL-DS71 RAM Replacement, Top Rear Panel: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
    FixBot'a Sor
    Yorum Ekle
  6. Asus ROG G751JL-DS71 RAM Replacement: adım 6, 2 resimden 1. Asus ROG G751JL-DS71 RAM Replacement: adım 6, 2 resimden 2.
    • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
    FixBot'a Sor
    Yorum Ekle
  7. Asus ROG G751JL-DS71 RAM Replacement: adım 7, 3 resimden 1. Asus ROG G751JL-DS71 RAM Replacement: adım 7, 3 resimden 2. Asus ROG G751JL-DS71 RAM Replacement: adım 7, 3 resimden 3.
    • Use a nylon spudger to carefully pry the top back panel off.
    • While removing the top back panel, be careful not to break the four pin connector located underneath.
    • Disconnect the four-pin connector and remove the top back panel from the computer.
    FixBot'a Sor
    Yorum Ekle
  8. Asus ROG G751JL-DS71 RAM Replacement, Keyboard: adım 8, 3 resimden 1. Asus ROG G751JL-DS71 RAM Replacement, Keyboard: adım 8, 3 resimden 2. Asus ROG G751JL-DS71 RAM Replacement, Keyboard: adım 8, 3 resimden 3.
    • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
    • Lift away the metal housings from each side of the laptop.
    FixBot'a Sor
    Yorum Ekle
  9. Asus ROG G751JL-DS71 RAM Replacement: adım 9, 2 resimden 1. Asus ROG G751JL-DS71 RAM Replacement: adım 9, 2 resimden 2.
    • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
    • Use a Phillips 1 Screwdriver to remove the four 5.2 mm screws underneath the center panel.
    FixBot'a Sor
    Yorum Ekle
  10. Asus ROG G751JL-DS71 RAM Replacement: adım 10, 3 resimden 1. Asus ROG G751JL-DS71 RAM Replacement: adım 10, 3 resimden 2. Asus ROG G751JL-DS71 RAM Replacement: adım 10, 3 resimden 3.
    • Use a plastic opening tool to pry the keyboard from the base of the laptop.
    • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
    FixBot'a Sor
    Yorum Ekle
  11. Asus ROG G751JL-DS71 RAM Replacement: adım 11, 2 resimden 1. Asus ROG G751JL-DS71 RAM Replacement: adım 11, 2 resimden 2.
    • Use a pair of tweezers to undo each of the four ribbon connectors.
    • The keyboard is now completely disconnected from the laptop and you can remove it.
    FixBot'a Sor
    Yorum Ekle
  12. Asus ROG G751JL-DS71 RAM Replacement, RAM: adım 12, 2 resimden 1. Asus ROG G751JL-DS71 RAM Replacement, RAM: adım 12, 2 resimden 2.
    • First locate the RAM.
    • Then pull the tabs located on the left and right of the RAM outwards to release the RAM.
    • You can now remove the RAM and replace it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Gwennie Kidd
147 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S16-G1, Banghart Winter 2018 Cal Poly, Team S16-G1, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S16G1
4 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 11
Son 30 gün: 35
Her zaman: 1,455
