Ana içeriğe geç
Asus ROG G751JT-DH72 CD Drive Replacement
Neye ihtiyacın var
  1. Asus ROG G751JT-DH72 CD Drive  Replacement, CD drive: adım 1, 1 resimden 1.
    • Lift up the rubber tab located in the upper-right corner of the backing plate.
  2. Asus ROG G751JT-DH72 CD Drive  Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the 5.2 mm screw behind the rubber tap.
  3. Asus ROG G751JT-DH72 CD Drive  Replacement: adım 3, 1 resimden 1.
    • Carefully pull the backing plate off. If you have a pry tool, you can pry on the edges carefully.
  4. Asus ROG G751JT-DH72 CD Drive  Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the 5 mm screw.
  5. Asus ROG G751JT-DH72 CD Drive  Replacement: adım 5, 1 resimden 1.
    • Pull out the drive and remove it from the device.
Sonuç
Anum Haidari
558 İtibar
3 adet Kılavuz yazıldı
Ekip
UC Davis, Team S7-G4, Lore Fall 2018 UC Davis, Team S7-G4, Lore Fall 2018 üyesi
UCD-LORE-F18S7G4
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 238
