Ana içeriğe geç
Asus ROG G751JT-DH72 RAM Replacement
Neye ihtiyacın var
  1. Asus ROG G751JT-DH72 RAM Replacement, RAM: adım 1, 2 resimden 1. Asus ROG G751JT-DH72 RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Lift up the rubber tab located in the upper-right corner of the backing plate.
  2. Asus ROG G751JT-DH72 RAM Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the 5.2 mm screw behind the rubber tap.
  3. Asus ROG G751JT-DH72 RAM Replacement: adım 3, 1 resimden 1.
    • Carefully pull the backing plate off. If you have a pry tool, you can pry on the edges carefully.
  4. Asus ROG G751JT-DH72 RAM Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the 5mm screw on the right side.
  5. Asus ROG G751JT-DH72 RAM Replacement: adım 5, 1 resimden 1.
    • Pull out the optical drive to revel the screws holding the laptop cover.
  6. Asus ROG G751JT-DH72 RAM Replacement: adım 6, 2 resimden 1. Asus ROG G751JT-DH72 RAM Replacement: adım 6, 2 resimden 2.
    • Remove all 10 5.2mm Phillips screws holding the main back cover using the Phillips #1 screwdriver.
  7. Asus ROG G751JT-DH72 RAM Replacement: adım 7, 1 resimden 1.
    • Remove the four 5.2mm screws directly behind the backing plate using the Phillips #1 screwdriver.
  8. Asus ROG G751JT-DH72 RAM Replacement: adım 8, 1 resimden 1.
    • Flip over the laptop and pry the 2 vent covers off.
  9. Asus ROG G751JT-DH72 RAM Replacement: adım 9, 1 resimden 1.
    • Remove the two 6.8mm Phillips screws directly below the vent covers using the Phillips #1 screwdriver.
  10. Asus ROG G751JT-DH72 RAM Replacement: adım 10, 2 resimden 1. Asus ROG G751JT-DH72 RAM Replacement: adım 10, 2 resimden 2.
    • Pry along the edges of the keyboard to lift it up.
    • Be careful not to damage the ribbon connectors.
  11. Asus ROG G751JT-DH72 RAM Replacement: adım 11, 2 resimden 1. Asus ROG G751JT-DH72 RAM Replacement: adım 11, 2 resimden 2.
    • Disconnect all 4 ribbon connectors with a tweezer.
  12. Asus ROG G751JT-DH72 RAM Replacement: adım 12, 1 resimden 1.
    • Carefully, pull on the side tabs to release the RAM card.
Sonuç
Anum Haidari
558 İtibar
3 adet Kılavuz yazıldı
Ekip
UC Davis, Team S7-G4, Lore Fall 2018 UC Davis, Team S7-G4, Lore Fall 2018 üyesi
UCD-LORE-F18S7G4
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 1,161
