Ana içeriğe geç
Asus ROG GL551J Hard Drive Replacement
Neye ihtiyacın var
  1. Asus ROG GL551J Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Hard Drive Replacement: adım 2, 1 resimden 1.
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Hard Drive Replacement: adım 3, 1 resimden 1.
    • Pull the battery out.
  4. Asus ROG GL551J Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. Asus ROG GL551J Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • With laptop upside-down, locate and unscrew the two screws on the panel with the vents.
    • Slide the panel out and lift up to remove.
  5. Asus ROG GL551J Hard Drive Replacement: adım 5, 2 resimden 1. Asus ROG GL551J Hard Drive Replacement: adım 5, 2 resimden 2.
    • The hard drive is the metal rectangle with the two soft padding bars attached to it.
    • Locate and remove the 4 screws holding the hard drive down at each corner using a PH000 Philips head.
  6. Asus ROG GL551J Hard Drive Replacement: adım 6, 2 resimden 1. Asus ROG GL551J Hard Drive Replacement: adım 6, 2 resimden 2.
    • Locate the black plastic tab attached to the bottom of the hard drive and pull it straight outwards.
    • Failure to correctly disconnect the hard drive before pulling it up and out can damage the connectors.
    • Once the hard drive detaches from the connector, lift the hard drive up and out.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Thien Vu
412 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-4, Lacy Spring 2017 USF Tampa, Team 5-4, Lacy Spring 2017 üyesi
USFT-LACY-S17S5G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 4,483
