Ana içeriğe geç
Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement
Neye ihtiyacın var
  1. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Back Panel: adım 1, 2 resimden 1. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Back Panel: adım 1, 2 resimden 2.
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: adım 2, 3 resimden 1. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: adım 2, 3 resimden 2. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: adım 2, 3 resimden 3.
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove the four 4 mm screws holding the hard drive.
  4. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Pull the hard drive directly away from the fan just above it.
    • The connecting pins should slide out easily, but you might have to move the hard drive around a bit to loosen the pins.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Zach Langer
676 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G2, Forte Spring 2017 Cal Poly, Team S13-G2, Forte Spring 2017 üyesi
CPSU-FORTE-S17S13G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 7,114
