Ana içeriğe geç
Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement
Neye ihtiyacın var
  1. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Back Panel: adım 1, 2 resimden 1. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Back Panel: adım 1, 2 resimden 2.
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: adım 2, 3 resimden 1. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: adım 2, 3 resimden 2. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: adım 2, 3 resimden 3.
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Battery: adım 3, 1 resimden 1.
    • Unplug the battery from the motherboard.
  4. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: adım 4, 3 resimden 1. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: adım 4, 3 resimden 2. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: adım 4, 3 resimden 3.
    • Unscrew the 3.8 mm Phillips #1 screw on the top right hand corner of the battery.
    • Lift battery from laptop frame.
  5. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Wifi Card: adım 5, 3 resimden 1. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Wifi Card: adım 5, 3 resimden 2. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Wifi Card: adım 5, 3 resimden 3.
    • Using the iFixit Opening Tool, disconnect the black and white coaxial cables from the wifi card.
    • Using a Phillips #1 screwdriver, remove the 4mm retaining screw.
    • Gently slide the wifi card out from the connection slot.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 53
Her zaman: 2,412
