Ana içeriğe geç
Asus ROG Strix GL702VS Fan Replacement
Neye ihtiyacın var
    1. Asus ROG Strix GL702VS Fan Replacement, Back Cover: adım 1, 1 resimden 1.
      • Flip the computer so the bottom of the laptop is facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Asus ROG Strix GL702VS Fan Replacement: adım 2, 1 resimden 1.
      • Remove the ten JIS #0 screws around the edge of the laptop.
      • The two bottom screws are slightly shorter
      FixBot'a Sor
      Yorum Ekle
    3. Asus ROG Strix GL702VS Fan Replacement: adım 3, 2 resimden 1. Asus ROG Strix GL702VS Fan Replacement: adım 3, 2 resimden 2.
      • Use a Jimmy to carefully free each side of the bottom casing.
      FixBot'a Sor
      Yorum Ekle
    4. Asus ROG Strix GL702VS Fan Replacement: adım 4, 1 resimden 1.
      • Lift up the back casing from the computer.
      • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
      FixBot'a Sor
      Yorum Ekle
    1. Asus ROG Strix GL702VS Fan Replacement, Cooling Fans: adım 5, 3 resimden 1. Asus ROG Strix GL702VS Fan Replacement, Cooling Fans: adım 5, 3 resimden 2. Asus ROG Strix GL702VS Fan Replacement, Cooling Fans: adım 5, 3 resimden 3.
      • Remove the four 4.8mm JIS #0 screws (two on each fan).
      FixBot'a Sor
      Yorum Ekle
    2. Asus ROG Strix GL702VS Fan Replacement: adım 6, 3 resimden 1. Asus ROG Strix GL702VS Fan Replacement: adım 6, 3 resimden 2. Asus ROG Strix GL702VS Fan Replacement: adım 6, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Remove the fan's connector on the motherboard using a pair of tweezers.
      • Be gentle, as the small clips and wires can be easily damaged.
      FixBot'a Sor
      Yorum Ekle
    3. Asus ROG Strix GL702VS Fan Replacement: adım 7, 2 resimden 1. Asus ROG Strix GL702VS Fan Replacement: adım 7, 2 resimden 2.
      • Gently lift each fan up and out of position.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 42
Her zaman: 3,492
