Ana içeriğe geç
Asus ROG Strix GL702VS LCD Screen (Display) Replacement
Neye ihtiyacın var
    1. Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): adım 1, 3 resimden 1. Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): adım 1, 3 resimden 2. Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): adım 1, 3 resimden 3.
      • Remove the two screw stickers at the bottom corners of the screen.
      • Remove the two 4mm JIS #0 screws beneath the stickers.
      FixBot'a Sor
      Yorum Ekle
    2. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: adım 2, 3 resimden 1. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: adım 2, 3 resimden 2. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: adım 2, 3 resimden 3.
      • Break the glue between the bezel and screen with a nylon spudger, working around the inside of the bezel.
      • Using an opening tool, lift up the bezel once the glue has been removed.
      • The plastic clips remain so it will have some resistance/snapping noises.
      FixBot'a Sor
      Yorum Ekle
    3. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: adım 3, 2 resimden 1. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: adım 3, 2 resimden 2.
      • Lift the plastic bezel off of the front display panel.
      • The plastic bezel will click when put back on the screen.
      FixBot'a Sor
      Yorum Ekle
    4. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: adım 4, 1 resimden 1.
      • Remove the four interior 4mm JIS #0 screws from each of the four metal LCD tabs.
      FixBot'a Sor
      Yorum Ekle
    5. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: adım 5, 3 resimden 1. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: adım 5, 3 resimden 2. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: adım 5, 3 resimden 3.
      • Once the LCD display is freed you can lift it up out of the casing.
      • Be careful as the cable remains attached.
      FixBot'a Sor
      Yorum Ekle
    6. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: adım 6, 2 resimden 1. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: adım 6, 2 resimden 2.
      Bu adımda kullanılan alet:
      • On the backside of the LCD, disconnect the LCD cable using a pair of tweezers.
      • Once fully disconnected, remove the LCD and replace it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 46
Her zaman: 2,365
