Ana içeriğe geç
Asus ROG Strix GL702VS Trackpad Replacement
Neye ihtiyacın var
    1. Asus ROG Strix GL702VS Trackpad Replacement, Back Cover: adım 1, 1 resimden 1.
      • Flip the computer so the bottom of the laptop is facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Asus ROG Strix GL702VS Trackpad Replacement: adım 2, 1 resimden 1.
      • Remove the ten JIS #0 screws around the edge of the laptop.
      • The two bottom screws are slightly shorter
      FixBot'a Sor
      Yorum Ekle
    3. Asus ROG Strix GL702VS Trackpad Replacement: adım 3, 2 resimden 1. Asus ROG Strix GL702VS Trackpad Replacement: adım 3, 2 resimden 2.
      • Use a Jimmy to carefully free each side of the bottom casing.
      FixBot'a Sor
      Yorum Ekle
    4. Asus ROG Strix GL702VS Trackpad Replacement: adım 4, 1 resimden 1.
      • Lift up the back casing from the computer.
      • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
      FixBot'a Sor
      Yorum Ekle
    1. Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: adım 5, 3 resimden 1. Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: adım 5, 3 resimden 2. Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: adım 5, 3 resimden 3.
      • Disconnect the ribbon cables from the connectors at the bottom of the motherboard by lifting up the tabs with a nylon spudger tool.
      • Slide the ribbon cables out of the connectors on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Asus ROG Strix GL702VS Trackpad Replacement: adım 6, 2 resimden 1. Asus ROG Strix GL702VS Trackpad Replacement: adım 6, 2 resimden 2.
      • Remove the covering foil holding the trackpad into place.
      • Completely peel the foil back to ensure it does not interfere with the following processes.
      FixBot'a Sor
      Yorum Ekle
    3. Asus ROG Strix GL702VS Trackpad Replacement: adım 7, 2 resimden 1. Asus ROG Strix GL702VS Trackpad Replacement: adım 7, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Lift up speaker cable that is laying overtop using a pair of tweezers.
      • Do not to overextend the wire since you may accidently pull the wire out.
      FixBot'a Sor
      Yorum Ekle
    4. Asus ROG Strix GL702VS Trackpad Replacement: adım 8, 3 resimden 1. Asus ROG Strix GL702VS Trackpad Replacement: adım 8, 3 resimden 2. Asus ROG Strix GL702VS Trackpad Replacement: adım 8, 3 resimden 3.
      • Remove the three 4mm JIS #0 screws that are securing the trackpad.
      FixBot'a Sor
      Yorum Ekle
    5. Asus ROG Strix GL702VS Trackpad Replacement: adım 9, 2 resimden 1. Asus ROG Strix GL702VS Trackpad Replacement: adım 9, 2 resimden 2.
      • Once freed, slide the trackpad backwards towards the center of laptop.
      • This may require some jiggling. Lifting the laptop off your working surface may help.
      • Sliding the trackpad back in can be a bit tricky. Ensure it is fully seated before continuing reassembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 40
Her zaman: 1,394
