Ana içeriğe geç
Asus ROG Strix GL702VS Webcam Replacement
Neye ihtiyacın var
  1. Asus ROG Strix GL702VS Webcam Replacement, LCD Screen (Display): adım 1, 3 resimden 1. Asus ROG Strix GL702VS Webcam Replacement, LCD Screen (Display): adım 1, 3 resimden 2. Asus ROG Strix GL702VS Webcam Replacement, LCD Screen (Display): adım 1, 3 resimden 3.
    • Remove the two screw stickers at the bottom corners of the screen.
    • Remove the two 4mm JIS #0 screws beneath the stickers.
  2. Asus ROG Strix GL702VS Webcam Replacement: adım 2, 3 resimden 1. Asus ROG Strix GL702VS Webcam Replacement: adım 2, 3 resimden 2. Asus ROG Strix GL702VS Webcam Replacement: adım 2, 3 resimden 3.
    • Break the glue between the bezel and screen with a nylon spudger, working around the inside of the bezel.
    • Using an opening tool, lift up the bezel once the glue has been removed.
    • The plastic clips remain so it will have some resistance/snapping noises.
  3. Asus ROG Strix GL702VS Webcam Replacement: adım 3, 2 resimden 1. Asus ROG Strix GL702VS Webcam Replacement: adım 3, 2 resimden 2.
    • Lift the plastic bezel off of the front display panel.
    • The plastic bezel will click when put back on the screen.
  4. Asus ROG Strix GL702VS Webcam Replacement: adım 4, 1 resimden 1.
    • Remove the four interior 4mm JIS #0 screws from each of the four metal LCD tabs.
  5. Asus ROG Strix GL702VS Webcam Replacement: adım 5, 3 resimden 1. Asus ROG Strix GL702VS Webcam Replacement: adım 5, 3 resimden 2. Asus ROG Strix GL702VS Webcam Replacement: adım 5, 3 resimden 3.
    • Once the LCD display is freed you can lift it up out of the casing.
    • Be careful as the cable remains attached.
  6. Asus ROG Strix GL702VS Webcam Replacement: adım 6, 2 resimden 1. Asus ROG Strix GL702VS Webcam Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • On the backside of the LCD, disconnect the LCD cable using a pair of tweezers.
    • Once fully disconnected, remove the LCD and replace it.
  7. Asus ROG Strix GL702VS Webcam Replacement, Webcam: adım 7, 1 resimden 1.
    • Gently lift the webcam out of its resting position at the top of the LCD assembly.
  8. Asus ROG Strix GL702VS Webcam Replacement: adım 8, 2 resimden 1. Asus ROG Strix GL702VS Webcam Replacement: adım 8, 2 resimden 2.
    • Using the nylon tweezers or your hand, disconnect the webcam module.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 565
