Ana içeriğe geç
Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement
Neye ihtiyacın var
  1. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement, Front Side M.2 SSD: adım 1, 2 resimden 1. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement, Front Side M.2 SSD: adım 1, 2 resimden 2.
    • Remove the front panel.
    • This may involve one or two thumb screws depending on your case.
  2. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: adım 2, 1 resimden 1.
    • Detach the PSU cable from your graphics card.
  3. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: adım 3, 3 resimden 1. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: adım 3, 3 resimden 2. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: adım 3, 3 resimden 3.
    • Unscrew the back panel screws to release the graphics card.
    • Release the PCIe switch.
    • Be careful when using a tool as you can damage the motherboard if the tool slips.
    • Take the graphics card out vertically.
  4. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: adım 4, 3 resimden 1. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: adım 4, 3 resimden 2. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: adım 4, 3 resimden 3.
    • Unscrew the heat-sink screws.
    • Remove the heat-sink vertically.
    • It is important to remove it vertically as there are pins on the right side that must not be bent.
  5. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: adım 5, 3 resimden 1. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: adım 5, 3 resimden 2. Asus ROG Strix X570-I Mini ITX Motherboard M.2 SSD Replacement: adım 5, 3 resimden 3.
    • Unscrew the small screw holding the SSD.
    • Remove the SSD at an angle.
    • Be careful to avoid grabbing the SSD from its circuit.
    • Insert a new SSD at a 30-40 degree angle.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 66
Her zaman: 3,752
