Giriş
The motherboard is connected to everything within the computer, so if it sustains damage, likely the machine will not function smoothly.
If you motherboard has been broken or exposed to water, this guide will show you how to remove it.
Neye ihtiyacın var
Remove the 1.6 mm and 9 mm screws from the back panel using the Phillips #1 screwdriver.
Neredeyse bitti!
Sonuç
