Ana içeriğe geç
Asus ROG Zephyrus G14 RAM Replacement
Neye ihtiyacın var
  1. Asus ROG Zephyrus G14 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Make sure to power off your laptop and unplug all accessories when disassembling to avoid damage.
    • Place the laptop so the backplate faces up.
  2. Asus ROG Zephyrus G14 RAM Replacement: adım 2, 3 resimden 1. Asus ROG Zephyrus G14 RAM Replacement: adım 2, 3 resimden 2. Asus ROG Zephyrus G14 RAM Replacement: adım 2, 3 resimden 3.
    • Remove the screws on the back. Unscrew them with a Phillips #0 screwdriver.
    • Remove the three (2x4.5mm) screws from the front of the laptop.
    • Remove the ten (2x9mm) screws from the middle and back of the laptop.
    • Unscrew the (2x6mm) captive screw in the bottom right without removing it.
  3. Asus ROG Zephyrus G14 RAM Replacement: adım 3, 3 resimden 1. Asus ROG Zephyrus G14 RAM Replacement: adım 3, 3 resimden 2. Asus ROG Zephyrus G14 RAM Replacement: adım 3, 3 resimden 3.
    • Turn the computer around and pull up on the back panel to remove it.
  4. Asus ROG Zephyrus G14 RAM Replacement: adım 4, 3 resimden 1. Asus ROG Zephyrus G14 RAM Replacement: adım 4, 3 resimden 2. Asus ROG Zephyrus G14 RAM Replacement: adım 4, 3 resimden 3.
    • Rotate the laptop around so the battery is facing towards you.
    • After you have located the RAM slot on the motherboard, disconnect the battery on the laptop to prevent any electrical shorts that may happen if you accidentally touch any of the components on the motherboard.
    • Pull back on the black plastic that covers the RAM slot.
  5. Asus ROG Zephyrus G14 RAM Replacement: adım 5, 3 resimden 1. Asus ROG Zephyrus G14 RAM Replacement: adım 5, 3 resimden 2. Asus ROG Zephyrus G14 RAM Replacement: adım 5, 3 resimden 3.
    • If there is a RAM stick currently in the laptop, pull the tabs on the left and right to allow the RAM to pop up.
  6. Asus ROG Zephyrus G14 RAM Replacement: adım 6, 3 resimden 1. Asus ROG Zephyrus G14 RAM Replacement: adım 6, 3 resimden 2. Asus ROG Zephyrus G14 RAM Replacement: adım 6, 3 resimden 3.
    • Align and insert the RAM into the slot and push it down.
    • Once the RAM clicks into place, check to make sure that the RAM is locked in place.
    • After you have installed your new RAM stick, plug the battery back into the motherboard before putting the back panel on the laptop.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Something that might be helpful for this guide is including the RAM specifications needed for an upgrade if people are looking for information on what to buy.
Otherwise, great guide!
Andy Merskin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 73
Son 30 gün: 304
Her zaman: 17,115
