Ana içeriğe geç
Asus ROG Zephyrus M15 GU502L Touchpad Replacement
Neye ihtiyacın var
  1. Asus ROG Zephyrus M15 GU502L Touchpad Replacement, Battery: adım 1, 2 resimden 1. Asus ROG Zephyrus M15 GU502L Touchpad Replacement, Battery: adım 1, 2 resimden 2.
    • Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
  2. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: adım 2, 2 resimden 1. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to separate the back cover from the laptop.
    • It is recommended that you separate the laptop cover from the side and run the tool along the edge of the cover to open it.
    • Be careful not to damage the cover when removing it from the laptop.
  3. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: adım 3, 1 resimden 1.
    • Remove six 4.8 mm screws that secure the battery using a Phillips #00 screwdriver.
  4. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: adım 4, 2 resimden 1. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the 8-pin battery that secures the battery to the motherboard.
    • Use the nylon tipped reverse tweezers to squeeze the edges, then pull out the connector.
  5. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: adım 5, 1 resimden 1.
    • Remove the battery from the computer.
  6. Asus ROG Zephyrus M15 GU502L Touchpad Replacement, Touchpad: adım 6, 1 resimden 1.
    • Remove the 3mm screws that secure the touchpad using a Phillips #0 screwdriver.
  7. Asus ROG Zephyrus M15 GU502L Touchpad Replacement: adım 7, 1 resimden 1.
    • Remove the touch pad from the casing.
    • Be cautious picking up the touch pad as it is light.
Sonuç
Yahir Donis
339 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team 69-69, Gonzalez Fall 2023 Gateway, Team 69-69, Gonzalez Fall 2023 üyesi
GCC-GONZALEZ-F23S69G69
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 147
