Giriş
This guide will teach you how to disassemble the laptop for repairs that require the removal of the motherboard. This guide is required to replace the screen and speakers on the laptop.
Neye ihtiyacın var
Flip the laptop over so the backside is facing upwards.
Using both hands, slide the lock mechanisms outwards and pull up to remove the battery.
Remove the nine 15.4mm Phillips #00 screws.
Remove the four 8.7mm Phillips #00 screws from the hard drive mounting bracket.
Remove the hard drive bracket.
There is another screw next to the A near the CPU heatsink and RAM that also needs to be taken out.
Additionally, there is a screw beneath the optical drive that attaches to the keyboard. While the laptop is upside down, slide the optical drive completely out, and remove the shallow screw near the lip of the chassis. This should be done prior to the next step of lifting the keyboard with a pry tool.
Remove the CD/DVD drive by sliding it out of the side of the laptop.
Gently remove the ribbon cables and wireless chip. A plastic prying tool will help in this removal.
Remove the power cable for the motherboard.
Remove the power cable for the speaker.
i broke my ribbon cable when i was reconnecting it, is there a way to have a guide into how to repair that connection?
Once you’ve removed most of those lengths of cables, they are really only held on by some tape you could just by a new cable. However if you’re talking about the port that it connects to on the motherboard you'll need to get really handy with a hot work station or buy a new mother board.
6 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
How to assemble it again? I don't have much experience and will do it for the first time watching your guide. Thank you!!
