Ana içeriğe geç
Asus Rog GL55VW-DH71 Disassembly
Neye ihtiyacın var
  1. Asus Rog GL55VW-DH71 Disassembly, Battery: adım 1, 3 resimden 1. Asus Rog GL55VW-DH71 Disassembly, Battery: adım 1, 3 resimden 2. Asus Rog GL55VW-DH71 Disassembly, Battery: adım 1, 3 resimden 3.
    • Flip the laptop over so the backside is facing upwards.
    • Using both hands, slide the lock mechanisms outwards and pull up to remove the battery.
  2. Asus Rog GL55VW-DH71 Disassembly, Keyboard: adım 2, 3 resimden 1. Asus Rog GL55VW-DH71 Disassembly, Keyboard: adım 2, 3 resimden 2. Asus Rog GL55VW-DH71 Disassembly, Keyboard: adım 2, 3 resimden 3.
    • Remove the nine 15.4mm Phillips #00 screws.
    • Remove the four 8.7mm Phillips #00 screws from the hard drive mounting bracket.
    • Remove the hard drive bracket.
    There is another screw next to the A near the CPU heatsink and RAM that also needs to be taken out.
    marcus lee - Yanıt
    Additionally, there is a screw beneath the optical drive that attaches to the keyboard. While the laptop is upside down, slide the optical drive completely out, and remove the shallow screw near the lip of the chassis. This should be done prior to the next step of lifting the keyboard with a pry tool.
    Edward McLean - Yanıt
  3. Asus Rog GL55VW-DH71 Disassembly: adım 3, 2 resimden 1. Asus Rog GL55VW-DH71 Disassembly: adım 3, 2 resimden 2.
    • Flip laptop over and open the screen.
    • Wedge some plastic opening tools between the keyboard and case.
    • Work your way around with the plastic opening tools until the keyboard is separate from the case.
    • Do not try to lift the keyboard straight off at this time. There are some ribbon cables that attach the motherboard to the keyboard that need to be removed first.
  4. Asus Rog GL55VW-DH71 Disassembly: adım 4, 3 resimden 1. Asus Rog GL55VW-DH71 Disassembly: adım 4, 3 resimden 2. Asus Rog GL55VW-DH71 Disassembly: adım 4, 3 resimden 3.
    • Remove the ZIF connected ribbon cables for the touchpad and keyboard by gently lifting the latch on the connector point, then slide the ribbon cable out. Repeat for each cable.
    • Verify all ribbon cables are disconnected and out of the way, and lift the keyboard out of the assembly.
  5. Asus Rog GL55VW-DH71 Disassembly, Asus Rog GL55VW-DH71 Disassembly: adım 5, 1 resimden 1.
    • Remove the CD/DVD drive by sliding it out of the side of the laptop.
  6. Asus Rog GL55VW-DH71 Disassembly: adım 6, 3 resimden 1. Asus Rog GL55VW-DH71 Disassembly: adım 6, 3 resimden 2. Asus Rog GL55VW-DH71 Disassembly: adım 6, 3 resimden 3.
    • Remove the three 6.5mm Phillips #00 screws from the fan.
    • Disconnect the fan power cable from the motherboard.
    • Remove the fan.
  7. Asus Rog GL55VW-DH71 Disassembly: adım 7, 3 resimden 1. Asus Rog GL55VW-DH71 Disassembly: adım 7, 3 resimden 2. Asus Rog GL55VW-DH71 Disassembly: adım 7, 3 resimden 3.
    • Gently remove the ribbon cables and wireless chip. A plastic prying tool will help in this removal.
    • Remove the power cable for the motherboard.
    • Remove the power cable for the speaker.
    i broke my ribbon cable when i was reconnecting it, is there a way to have a guide into how to repair that connection?
    dakalodev - Yanıt
    Once you’ve removed most of those lengths of cables, they are really only held on by some tape you could just by a new cable. However if you’re talking about the port that it connects to on the motherboard you'll need to get really handy with a hot work station or buy a new mother board.
    Don E Humphrey II -
  8. Asus Rog GL55VW-DH71 Disassembly: adım 8, 1 resimden 1.
    • Ensuring no missed connections or screws, remove the motherboard from the assembly.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Addison Thomas
1.232 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Nance Spring 2018 USF Tampa, Team S1-G2, Nance Spring 2018 üyesi
USFT-NANCE-S18S1G2
4 Üyeler
Bir Yorum
How to assemble it again? I don't have much experience and will do it for the first time watching your guide. Thank you!!
Yogesh Patil - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 61
Her zaman: 8,033
