Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will teach you how to remove and replace the speakers in your laptop. Special care must be taken, due to delicate parts and ribbon cables needed to be removed during the repair.
Neye ihtiyacın var
Flip the laptop over so the backside is facing upwards.
Using both hands, slide the lock mechanisms outwards and pull up to remove the battery.
Remove the nine 15.4mm Phillips #00 screws.
Remove the four 8.7mm Phillips #00 screws from the hard drive mounting bracket.
Remove the hard drive bracket.
Remove the CD/DVD drive by sliding it out of the side of the laptop.
2 farklı kişi bu kılavuzu tamamladı.
