Ana içeriğe geç
  1. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Flip the laptop over so the backside is facing upwards. Using both hands, slide the lock mechanisms outwards and pull up to remove the battery. Using both hands, slide the lock mechanisms outwards and pull up to remove the battery.
    • Flip the laptop over so the backside is facing upwards.
    • Using both hands, slide the lock mechanisms outwards and pull up to remove the battery.
  2. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the nine 15.4mm Phillips #00 screws. Remove the four 8.7mm Phillips #00 screws from the hard drive mounting bracket. Remove the hard drive bracket.
    • Remove the nine 15.4mm Phillips #00 screws.
    • Remove the four 8.7mm Phillips #00 screws from the hard drive mounting bracket.
    • Remove the hard drive bracket.
  3. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Flip laptop over and open the screen. Wedge some plastic opening tools between the keyboard and case.
    • Flip laptop over and open the screen.
    • Wedge some plastic opening tools between the keyboard and case.
    • Work your way around with the plastic opening tools until the keyboard is separate from the case.
    • Do not try to lift the keyboard straight off at this time. There are some ribbon cables that attach the motherboard to the keyboard that need to be removed first.
  4. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the ZIF connected ribbon cables for the touchpad and keyboard by gently lifting the latch on the connector point, then slide the ribbon cable out. Repeat for each cable. Verify all ribbon cables are disconnected and out of the way, and lift the keyboard out of the assembly. Verify all ribbon cables are disconnected and out of the way, and lift the keyboard out of the assembly.
    • Remove the ZIF connected ribbon cables for the touchpad and keyboard by gently lifting the latch on the connector point, then slide the ribbon cable out. Repeat for each cable.
    • Verify all ribbon cables are disconnected and out of the way, and lift the keyboard out of the assembly.
  5. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the ZIF connector ribbon cable from the back of the touchpad by carefully lifting the latch on the connector and sliding the cable out.
    • Remove the ZIF connector ribbon cable from the back of the touchpad by carefully lifting the latch on the connector and sliding the cable out.
  6. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the three 2.8mm Phillips #00 screws from the trackpad.
    • Remove the three 2.8mm Phillips #00 screws from the trackpad.
  7. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the tape. Pull the touchpad out of the assembly. Pull the touchpad out of the assembly.
    • Remove the tape.
    • Pull the touchpad out of the assembly.
Bitiş Çizgisi
Addison Thomas
1.149 İtibar
8 adet Kılavuz yazıldı
Takım
USF Tampa, Team S1-G2, Nance Spring 2018 USF Tampa, Team S1-G2, Nance Spring 2018 üyesi
USFT-NANCE-S18S1G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 50
Her zaman: 2,381
