Ana içeriğe geç
Asus Rog GL55VW-DH71 USB port Replacement
Neye ihtiyacın var
  1. Asus Rog GL55VW-DH71 USB port Replacement, Battery: adım 1, 3 resimden 1. Asus Rog GL55VW-DH71 USB port Replacement, Battery: adım 1, 3 resimden 2. Asus Rog GL55VW-DH71 USB port Replacement, Battery: adım 1, 3 resimden 3.
    • Flip the laptop over so the backside is facing upwards.
    • Using both hands, slide the lock mechanisms outwards and pull up to remove the battery.
  2. Asus Rog GL55VW-DH71 USB port Replacement, Keyboard: adım 2, 3 resimden 1. Asus Rog GL55VW-DH71 USB port Replacement, Keyboard: adım 2, 3 resimden 2. Asus Rog GL55VW-DH71 USB port Replacement, Keyboard: adım 2, 3 resimden 3.
    • Remove the nine 15.4mm Phillips #00 screws.
    • Remove the four 8.7mm Phillips #00 screws from the hard drive mounting bracket.
    • Remove the hard drive bracket.
    There is another screw next to the A near the CPU heatsink and RAM that also needs to be taken out.
    marcus lee - Yanıt
    Additionally, there is a screw beneath the optical drive that attaches to the keyboard. While the laptop is upside down, slide the optical drive completely out, and remove the shallow screw near the lip of the chassis. This should be done prior to the next step of lifting the keyboard with a pry tool.
    Edward McLean - Yanıt
  3. Asus Rog GL55VW-DH71 USB port Replacement: adım 3, 2 resimden 1. Asus Rog GL55VW-DH71 USB port Replacement: adım 3, 2 resimden 2.
    • Flip laptop over and open the screen.
    • Wedge some plastic opening tools between the keyboard and case.
    • Work your way around with the plastic opening tools until the keyboard is separate from the case.
    • Do not try to lift the keyboard straight off at this time. There are some ribbon cables that attach the motherboard to the keyboard that need to be removed first.
  4. Asus Rog GL55VW-DH71 USB port Replacement: adım 4, 3 resimden 1. Asus Rog GL55VW-DH71 USB port Replacement: adım 4, 3 resimden 2. Asus Rog GL55VW-DH71 USB port Replacement: adım 4, 3 resimden 3.
    • Remove the ZIF connected ribbon cables for the touchpad and keyboard by gently lifting the latch on the connector point, then slide the ribbon cable out. Repeat for each cable.
    • Verify all ribbon cables are disconnected and out of the way, and lift the keyboard out of the assembly.
  5. Asus Rog GL55VW-DH71 USB port Replacement, USB port: adım 5, 2 resimden 1. Asus Rog GL55VW-DH71 USB port Replacement, USB port: adım 5, 2 resimden 2.
    • The pictures shown are taken with the motherboard removed. This is not required for the replacement of the USB module.
    • Remove the two 2.8mm Phillips #00 screws.
    • Carefully remove the ZIF connector ribbon cable from the module by lifting up on the latch and pulling the cable out.
Sonuç
Addison Thomas
1.232 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Nance Spring 2018 USF Tampa, Team S1-G2, Nance Spring 2018 üyesi
USFT-NANCE-S18S1G2
4 Üyeler
Bir Yorum
Where do you find a replacement module? Does it have a specific product name?
Jonathan Magnes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,828
