Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Flip the laptop over so the backside is facing upwards.
Using both hands, slide the lock mechanisms outwards and pull up to remove the battery.
Remove the nine 15.4mm Phillips #00 screws.
Remove the four 8.7mm Phillips #00 screws from the hard drive mounting bracket.
Remove the hard drive bracket.
Flip laptop over and open the screen.
Wedge some plastic opening tools between the keyboard and case.
Work your way around with the plastic opening tools until the keyboard is separate from the case.
Remove the ZIF connected ribbon cables for the touchpad and keyboard by gently lifting the latch on the connector point, then slide the ribbon cable out. Repeat for each cable.
Verify all ribbon cables are disconnected and out of the way, and lift the keyboard out of the assembly.
Remove the two 2.8mm Phillips #00 screws.
Carefully remove the ZIF connector ribbon cable from the module by lifting up on the latch and pulling the cable out.
Bir Yorum
Where do you find a replacement module? Does it have a specific product name?
