Ana içeriğe geç
Asus TF300T Tablet Speaker Replacement
Neye ihtiyacın var
  1. Asus TF300T Tablet Speaker Replacement, Back Panel Removal: adım 1, 3 resimden 1. Asus TF300T Tablet Speaker Replacement, Back Panel Removal: adım 1, 3 resimden 2. Asus TF300T Tablet Speaker Replacement, Back Panel Removal: adım 1, 3 resimden 3.
    • Begin the process by making sure that the dock is disconnected and the power is turned off.
    • Start by using the plastic opening tool on the side opposite the dock/ charging port. Begin to open the device along the short sides of the tablet.
    • When you have reached the side with the charging/ dock port be gentle with the opening tool due to the thinner plastic that could be broken with excessive force.
    • Once the opening tools have completely made their way around the device use the spudger to separate the back panel from the screen and expose the inside.
  2. Asus TF300T Tablet Speaker Replacement, Turn Off the Power: adım 2, 1 resimden 1.
    • The Asus Transformer series tablets have a hard power switch. This should be turned off before working on the tablet.
    • Locate the power switch near the power button on the top left. Use a tool to slide it to the position marked 'off'
    • For many repairs, like replacing the screen or digitizer, you do not need to remove the battery once you hve turned the tablet off. Be very careful not to short anything out with metal tools!
  3. Asus TF300T Tablet Speaker Replacement, Battery Removal: adım 3, 3 resimden 1. Asus TF300T Tablet Speaker Replacement, Battery Removal: adım 3, 3 resimden 2. Asus TF300T Tablet Speaker Replacement, Battery Removal: adım 3, 3 resimden 3.
    • Using the Phillips #00 screwdriver remove all of the screws connecting the battery to the mother board.
    • Once the initial screws have been removed as indicated by the photo, use the spudger to remove the cover concealing the the clips for the dock sensor and a few more screws.
    • Again remove the screws with the same screwdriver and use the spudger to disconnect the spudger sesors from their respective clips.
    • Once the battery is freed use the spudger to remove the battery from its spot
  4. Asus TF300T Tablet Speaker Replacement, Speaker Removal: adım 4, 3 resimden 1. Asus TF300T Tablet Speaker Replacement, Speaker Removal: adım 4, 3 resimden 2. Asus TF300T Tablet Speaker Replacement, Speaker Removal: adım 4, 3 resimden 3.
    • After the battery has been removed, remove the black tape next to the speaker using the spudger.
    • When the tape is removed, remove all the 3mm screws holding the speaker unit in place with the Phillips #00 screwdriver.
    • Using the tweezers, remove the speaker unit from its clip as shown in the picture by pulling on the part with the wire coming out of it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jonathan Barros
1.231 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-6, Duarte Fall 2014 UMass Dartmouth, Team 2-6, Duarte Fall 2014 üyesi
UMASSD-DUARTE-F14S2G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 982
