Neye ihtiyacın var
With a Phillips 0-bit screwdriver, remove eight 5.0 mm screws on the silver brackets
With a Phillips 0-bit screwdriver, remove two 5.0 mm screws holding the edge of the fans in place
With a size 0 Phillips screwdriver, unscrew two 5 mm screws holding the trackpad in place located at the bottom of the trackpad.
Carefully unclip the connector base to remove the two touchpad cables.
Remove the trackpad by sliding forward and lifting up.
Bir başkası bu kılavuzu tamamladı.
