Ana içeriğe geç
Asus TUF Gaming FX705G Fan Replacement
Neye ihtiyacın var
  1. Asus TUF Gaming FX705G Fan Replacement, Back Cover: adım 1, 2 resimden 1. Asus TUF Gaming FX705G Fan Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Fan Replacement: adım 2, 2 resimden 1. Asus TUF Gaming FX705G Fan Replacement: adım 2, 2 resimden 2.
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Fan Replacement, Battery: adım 3, 2 resimden 1. Asus TUF Gaming FX705G Fan Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Fan Replacement: adım 4, 2 resimden 1. Asus TUF Gaming FX705G Fan Replacement: adım 4, 2 resimden 2.
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Fan Replacement, Fan: adım 5, 2 resimden 1. Asus TUF Gaming FX705G Fan Replacement, Fan: adım 5, 2 resimden 2.
    • Remove the five Phillips #00 screws from the fan casings.
    • The left fan has three screws and the right fan has two screws.
  6. Asus TUF Gaming FX705G Fan Replacement: adım 6, 3 resimden 1. Asus TUF Gaming FX705G Fan Replacement: adım 6, 3 resimden 2. Asus TUF Gaming FX705G Fan Replacement: adım 6, 3 resimden 3.
    • Unplug the cables that connect the fan to the motherboard.
  7. Asus TUF Gaming FX705G Fan Replacement: adım 7, 3 resimden 1. Asus TUF Gaming FX705G Fan Replacement: adım 7, 3 resimden 2. Asus TUF Gaming FX705G Fan Replacement: adım 7, 3 resimden 3.
    • Lift the motherboard to unclip the housing clip on the back of the fan.
    • Remove the fan.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
3 Yorum
A bit nerve-racking, but got the new CPU fan installed, seems to be working fine according to armory crate. I did note that the CPU fan plug was quite stiff but I did manage to carefully wiggle it out. Anyways found your instructions very helpful especially the pics.
Thank You.
1857classic - Yanıt
Is it possible to change the cpu an gpu I'm a noob for sure thanks
Like to change them to make it a better pc might not be able to FX705DY
Christopher Hall - Yanıt
This was very helpful. Thank you
Sue Olmos - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 116
Her zaman: 15,483
