Ana içeriğe geç
Asus TUF Gaming FX705G M.2 SSD Replacement
Neye ihtiyacın var
  1. Asus TUF Gaming FX705G M.2 SSD Replacement, Back Cover: adım 1, 2 resimden 1. Asus TUF Gaming FX705G M.2 SSD Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G M.2 SSD Replacement: adım 2, 2 resimden 1. Asus TUF Gaming FX705G M.2 SSD Replacement: adım 2, 2 resimden 2.
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G M.2 SSD Replacement, Battery: adım 3, 2 resimden 1. Asus TUF Gaming FX705G M.2 SSD Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G M.2 SSD Replacement: adım 4, 2 resimden 1. Asus TUF Gaming FX705G M.2 SSD Replacement: adım 4, 2 resimden 2.
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G M.2 SSD Replacement, M.2 SSD: adım 5, 1 resimden 1.
    • Remove the Phillips #00 screw on the left side of the M.2 SSD.
  6. Asus TUF Gaming FX705G M.2 SSD Replacement: adım 6, 1 resimden 1.
    • Gently lift the screw side of the SSD to approximately a 45 degree angle and pull away from slot to remove it from the laptop.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 48
Her zaman: 4,517
