Ana içeriğe geç
Asus TUF Gaming FX705G Track Pad Replacement
Neye ihtiyacın var
  1. Asus TUF Gaming FX705G Track Pad Replacement, Back Cover: adım 1, 2 resimden 1. Asus TUF Gaming FX705G Track Pad Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Track Pad Replacement: adım 2, 2 resimden 1. Asus TUF Gaming FX705G Track Pad Replacement: adım 2, 2 resimden 2.
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Track Pad Replacement, Battery: adım 3, 2 resimden 1. Asus TUF Gaming FX705G Track Pad Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Track Pad Replacement: adım 4, 2 resimden 1. Asus TUF Gaming FX705G Track Pad Replacement: adım 4, 2 resimden 2.
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G Track Pad Replacement, Track pad: adım 5, 2 resimden 1. Asus TUF Gaming FX705G Track Pad Replacement, Track pad: adım 5, 2 resimden 2.
    • Take the ribbon wire out of the track pad.
  6. Asus TUF Gaming FX705G Track Pad Replacement: adım 6, 2 resimden 1. Asus TUF Gaming FX705G Track Pad Replacement: adım 6, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two screws holding the track pad in place.
  7. Asus TUF Gaming FX705G Track Pad Replacement: adım 7, 2 resimden 1. Asus TUF Gaming FX705G Track Pad Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Take the ground wire ribbon and pry it off of the motherboard housing with tweezers.
  8. Asus TUF Gaming FX705G Track Pad Replacement: adım 8, 3 resimden 1. Asus TUF Gaming FX705G Track Pad Replacement: adım 8, 3 resimden 2. Asus TUF Gaming FX705G Track Pad Replacement: adım 8, 3 resimden 3.
    • Use the iFixit opening tool to pry the track pad up slightly at the top and pull the latch at the top to free the track pad.
    • Slide the track pad up and out of the housing unit.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 30
Her zaman: 1,899
