Ana içeriğe geç
Asus Transformer Book T100TAF Keyboard Replacement
Neye ihtiyacın var
  1. Asus Transformer Book T100TAF Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Detach the keyboard from the screen by depressing the silver button on the hinge and pulling upwards on the tablet.
    FixBot'a Sor
    Yorum Ekle
  2. Asus Transformer Book T100TAF Keyboard Replacement: adım 2, 2 resimden 1. Asus Transformer Book T100TAF Keyboard Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the six 4 mm screws on the underside of the device.
    FixBot'a Sor
    Yorum Ekle
  3. Asus Transformer Book T100TAF Keyboard Replacement: adım 3, 2 resimden 1. Asus Transformer Book T100TAF Keyboard Replacement: adım 3, 2 resimden 2.
    • Use a metal spudger to pry up the rubber pads covering the two upper silver screws.
    • Use a Phillips #00 screwdriver to remove the two 5.5 mm screws under the rubber pads.
    FixBot'a Sor
    Yorum Ekle
  4. Asus Transformer Book T100TAF Keyboard Replacement: adım 4, 3 resimden 1. Asus Transformer Book T100TAF Keyboard Replacement: adım 4, 3 resimden 2. Asus Transformer Book T100TAF Keyboard Replacement: adım 4, 3 resimden 3.
    • Remove the back cover.
    • Use a Phillips #00 screwdriver to remove all the screws from the metal, inside panel, including four black 4.0 mm screws along the top.
    • Remove four black 3.0 screws along the bottom.
    • Remove the one silver 5.0 mm screw in the top right corner.
    FixBot'a Sor
    Yorum Ekle
  5. Asus Transformer Book T100TAF Keyboard Replacement: adım 5, 1 resimden 1.
    • Remove the metal keyboard cover from the device.
    FixBot'a Sor
    Yorum Ekle
  6. Asus Transformer Book T100TAF Keyboard Replacement: adım 6, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the 4.5 mm screw on the keyboard circuit board.
    FixBot'a Sor
    Yorum Ekle
  7. Asus Transformer Book T100TAF Keyboard Replacement: adım 7, 1 resimden 1.
    • Peel the yellow tape and label away from the motherboard with the metal spudger.
    FixBot'a Sor
    Yorum Ekle
  8. Asus Transformer Book T100TAF Keyboard Replacement: adım 8, 1 resimden 1.
    • Unplug the cable which leads to the hinge by gently pulling it away from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  9. Asus Transformer Book T100TAF Keyboard Replacement: adım 9, 3 resimden 1. Asus Transformer Book T100TAF Keyboard Replacement: adım 9, 3 resimden 2. Asus Transformer Book T100TAF Keyboard Replacement: adım 9, 3 resimden 3.
    • Flip up the tab on the white ribbon cable labeled “MB” using the metal spudger and then pull the white ribbon cable away from the motherboard.
    • Use a spudger to carefully flip up the black tab on the ZIF connector and pull the black striped ribbon cable away from the motherboard.
    • Don't use a metal spudger for work on the internals of your laptop. The photo in this guide is incorrect. The metal spudger is not ESD safe and could harm the components in your laptop.
    FixBot'a Sor
    Yorum Ekle
  10. Asus Transformer Book T100TAF Keyboard Replacement: adım 10, 1 resimden 1.
    • Gently remove the motherboard from the keyboard by pulling up with even pressure applied to all sides of the board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Elizabeth
589 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-3, Passmore Fall 2016 USF Tampa, Team 4-3, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S4G3
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Très facile. Merci. Et le fait d'avoir pu démonter mon clavier et souffler la poussière à l'intérieur à fait en sorte que les touches qui ne fonctionnaient plus ont recommencé à le faire. Merci encore.
Etienne Olemba - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 35
Her zaman: 7,943
