Giriş
This guide is going to teach you how to change your charging port if it is broken. If your tablet is not charging, replacing your charging port will help fix that problem.
Neye ihtiyacın var
Remove the tablet portion of the device from the keyboard by pushing the large silver button near the base of the tablet. Pull up on the tablet to remove from the keyboard.
Turn the tablet so that motherboard will be in the top right corner of the tablet and will be the largest of the green pieces.
Remove six 5mm Phillips #0 screws around the edge of the motherboard.
Remove three 3mm screws on the inner side of the motherboard.
Bu adımda kullanılan alet:Tweezers$4.99
Locate the 5 different clips around the edges of the motherboard.
The clips will be covered by either tape or a foam piece. You will need to remove this before unlatching the clips.
Unlatch the connections and use tweezers to remove the cables from the connections.
