Ana içeriğe geç
Asus Transformer Book T100TAR Motherboard Replacement
Neye ihtiyacın var
  1. Asus Transformer Book T100TAR Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Asus Transformer Book T100TAR Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Detach and separate the screen from the keyboard by pressing the silver release button at the base of the tablet.
  2. Asus Transformer Book T100TAR Motherboard Replacement: adım 2, 1 resimden 1.
    • Take the metal spudger and insert it into the seam of the rear cover casing and gently pry upwards.
    • If done correctly, you should feel the clips release.
    • Ensure that all the clips are released by sliding the metal opening tool along the four edges of the tablet.
    • Do not force the clips to release. This will cause them to break, and if broken, the screen will become loose. Open the rear cover gently and with caution.
  3. Asus Transformer Book T100TAR Motherboard Replacement: adım 3, 1 resimden 1.
    • Take off the rear case
  4. Asus Transformer Book T100TAR Motherboard Replacement: adım 4, 2 resimden 1. Asus Transformer Book T100TAR Motherboard Replacement: adım 4, 2 resimden 2.
    • Using a plastic opening tool, carefully lift up and detach the large black strip connecting from the camera board to the motherboard.
  5. Asus Transformer Book T100TAR Motherboard Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, detach the small black cable connected to the motherboard by gently tugging on it.
  6. Asus Transformer Book T100TAR Motherboard Replacement: adım 6, 3 resimden 1. Asus Transformer Book T100TAR Motherboard Replacement: adım 6, 3 resimden 2. Asus Transformer Book T100TAR Motherboard Replacement: adım 6, 3 resimden 3.
    • Using tweezers, carefully remove the black tape holding the large orange strip.
    • Using a plastic opening tool, lift up the white tabs and pull the orange strip out of place.
  7. Asus Transformer Book T100TAR Motherboard Replacement: adım 7, 2 resimden 1. Asus Transformer Book T100TAR Motherboard Replacement: adım 7, 2 resimden 2.
    • Disconnect the LCD connection apparatus by carefully removing the black protective strip with tweezers and gently tugging on the orange ribbon.
  8. Asus Transformer Book T100TAR Motherboard Replacement: adım 8, 1 resimden 1.
    • Using the nylon spudger, very carefully disconnect the battery by gently pushing the sharper end against the base.
    • There should be a small dent in the middle; push from there.
  9. Asus Transformer Book T100TAR Motherboard Replacement: adım 9, 1 resimden 1.
    • Using a Phillips #0 screwdriver, unscrew six 5mm screws holding the motherboard in place.
    • Also using a Phillips #0 screwdriver, unscrew two additional 4mm screws off the top left ends of the motherboard.
  10. Asus Transformer Book T100TAR Motherboard Replacement: adım 10, 1 resimden 1.
    • Disconnect the speaker from the motherboard by gently tugging on the cable head with tweezers.
  11. Asus Transformer Book T100TAR Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alyssa Ballesteros
683 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-1, Remmell Fall 2016 USF Tampa, Team 6-1, Remmell Fall 2016 üyesi
USFT-REMMELL-F16S6G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 927
