Ana içeriğe geç
Asus Transformer Flip Book TP200S WiFi Card Replacement
Neye ihtiyacın var
  1. Asus Transformer Flip Book TP200S WiFi Card Replacement, Battery: adım 1, 2 resimden 1. Asus Transformer Flip Book TP200S WiFi Card Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the back 6mm and 8mm screws with a J000 screwdriver.
  2. Asus Transformer Flip Book TP200S WiFi Card Replacement: adım 2, 1 resimden 1.
    • Remove the back cover of the flip book by gently using a metal spudger.
  3. Asus Transformer Flip Book TP200S WiFi Card Replacement: adım 3, 1 resimden 1.
    • Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
  4. Asus Transformer Flip Book TP200S WiFi Card Replacement: adım 4, 2 resimden 1. Asus Transformer Flip Book TP200S WiFi Card Replacement: adım 4, 2 resimden 2.
    • The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
    • Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
    • Gently remove the Wifi cables hooked to the rim of the battery
    • Remove the battery
  5. Asus Transformer Flip Book TP200S WiFi Card Replacement, WiFi Card: adım 5, 1 resimden 1.
    • The WiFi card will be covered by tape and attached to the motherboard.
    • Remove the tape from the WiFi card.
  6. Asus Transformer Flip Book TP200S WiFi Card Replacement: adım 6, 3 resimden 1. Asus Transformer Flip Book TP200S WiFi Card Replacement: adım 6, 3 resimden 2. Asus Transformer Flip Book TP200S WiFi Card Replacement: adım 6, 3 resimden 3.
    • Unscrew the WiFi card with a JIS #000 screwdriver.
    • Remove the motherboard connection from the WiFi card with tweezers.
    • Pull out the WiFi card.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alejandro Lopez
662 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S17-G2, Boczar Spring 2018 USF Tampa, Team S17-G2, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S17G2
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 781
