Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the back 6mm and 8mm screws with a J000 screwdriver.
Remove the back cover of the flip book by gently using a metal spudger.
Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
Gently remove the Wifi cables hooked to the rim of the battery
Remove the battery
Unscrew the WiFi card with a JIS #000 screwdriver.
Remove the motherboard connection from the WiFi card with tweezers.
Pull out the WiFi card.
Bir başkası bu kılavuzu tamamladı.
