Ana içeriğe geç
Asus Transformer Pad Infinity Charging Port Replacement
Neye ihtiyacın var
    1. Asus Transformer Pad Infinity Charging Port Replacement, Charging Port: adım 1, 2 resimden 1. Asus Transformer Pad Infinity Charging Port Replacement, Charging Port: adım 1, 2 resimden 2.
      • Take off the screen and the big motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Transformer Pad Infinity Charging Port Replacement: adım 2, 3 resimden 1. Asus Transformer Pad Infinity Charging Port Replacement: adım 2, 3 resimden 2. Asus Transformer Pad Infinity Charging Port Replacement: adım 2, 3 resimden 3.
      • Disconnect the long silver ribbon connector from the screen.
      • Remove the orange ribbon connector with the two connections.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Transformer Pad Infinity Charging Port Replacement: adım 3, 1 resimden 1.
      • Flip up the piece securing the ribbon to the big motherboard and remove the ribbon from the motherboard.
      • Note: This will have tape covering it, make sure not to cut the ribbon or scratch any other parts if you are looking to preserve these things.
      FixBot'a Sor
      Yorum Ekle
    4. Asus Transformer Pad Infinity Charging Port Replacement: adım 4, 1 resimden 1.
      • Remove the two screws holding the actual port, that goes to the outside of the device, in. This piece will be connected to the case.
      FixBot'a Sor
      Yorum Ekle
    5. Asus Transformer Pad Infinity Charging Port Replacement: adım 5, 1 resimden 1.
      • Once removing the damaged charging port, put in your new part and reassemble the device and check if the new charging port works.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Allison Poh
549 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G1
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 21
Her zaman: 1,539
