Ana içeriğe geç
Asus Transformer Pad Infinity Glass Replacement
Neye ihtiyacın var
  1. Asus Transformer Pad Infinity Glass Replacement, Glass: adım 1, 3 resimden 1. Asus Transformer Pad Infinity Glass Replacement, Glass: adım 1, 3 resimden 2. Asus Transformer Pad Infinity Glass Replacement, Glass: adım 1, 3 resimden 3.
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
    FixBot'a Sor
    Yorum Ekle
  2. Asus Transformer Pad Infinity Glass Replacement: adım 2, 1 resimden 1.
    • Remove the 4 screws around the metal portion of the screen (this is the LCD display).
    FixBot'a Sor
    Yorum Ekle
  3. Asus Transformer Pad Infinity Glass Replacement: adım 3, 1 resimden 1.
    • Peel the orange ribbon back (it has adhesive sticking itself to the black electric tape looking stuff surrounding the metal portion).
    FixBot'a Sor
    Yorum Ekle
  4. Asus Transformer Pad Infinity Glass Replacement: adım 4, 1 resimden 1.
    • Carefully place a preferably plastic tool between the glass portion and the electric tape looking stuff and pry off the screen from that portion.
    • Note: Take care as you’re dealing directly with with the glass and the way your touch input gets into the device.
    FixBot'a Sor
    Yorum Ekle
  5. Asus Transformer Pad Infinity Glass Replacement: adım 5, 1 resimden 1.
    • Once removed, replace the glass screen back onto the LCD display.
    • The new screen may or may not have new adhesive depending on where you got it. If it doesn’t, make sure you secure it with the screws safely.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Allison Poh
549 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G1
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 1,142
