Ana içeriğe geç
Asus Transformer T100 Battery Replacement
Neye ihtiyacın var
  1. Asus Transformer T100 Battery Replacement, Rear Cover: adım 1, 2 resimden 1. Asus Transformer T100 Battery Replacement, Rear Cover: adım 1, 2 resimden 2.
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
    FixBot'a Sor
    Yorum Ekle
  2. Asus Transformer T100 Battery Replacement: adım 2, 2 resimden 1. Asus Transformer T100 Battery Replacement: adım 2, 2 resimden 2.
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
    FixBot'a Sor
    Yorum Ekle
  3. Asus Transformer T100 Battery Replacement: adım 3, 1 resimden 1.
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
    FixBot'a Sor
    Yorum Ekle
  4. Asus Transformer T100 Battery Replacement: adım 4, 2 resimden 1. Asus Transformer T100 Battery Replacement: adım 4, 2 resimden 2.
    • Remove the rear casing.
    FixBot'a Sor
    Yorum Ekle
  5. Asus Transformer T100 Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Remove the copper tape carefully.
    FixBot'a Sor
    Yorum Ekle
  6. Asus Transformer T100 Battery Replacement: adım 6, 2 resimden 1. Asus Transformer T100 Battery Replacement: adım 6, 2 resimden 2.
    • Gently pull back the yellow transparent plastic covering on top of the battery connection port.
    FixBot'a Sor
    Yorum Ekle
  7. Asus Transformer T100 Battery Replacement: adım 7, 3 resimden 1. Asus Transformer T100 Battery Replacement: adım 7, 3 resimden 2. Asus Transformer T100 Battery Replacement: adım 7, 3 resimden 3.
    • Rotate the device so the top of the screen is facing you. Place the plastic opening tool underneath the battery and gently pry upwards to lift the battery out.
    • The battery wire harness will slide out as the battery is pried up.
    FixBot'a Sor
    Yorum Ekle
  8. Asus Transformer T100 Battery Replacement: adım 8, 2 resimden 1. Asus Transformer T100 Battery Replacement: adım 8, 2 resimden 2.
    • Remove the battery by slowly peeling the battery away from the connected side.
    • The adhesive on the back will pull away from the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
70 farklı kişi bu kılavuzu tamamladı.
Taylor Pantiga
1.629 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-31, Maness Spring 2014 Cal Poly, Team 13-31, Maness Spring 2014 üyesi
CPSU-MANESS-S14S13G31
3 Üyeler
8 adet Kılavuz yazıldı
22Kılavuz Yorumları
So I switched out my screen for it and its not turning on and I checked it everything was correctly place, but my Asus transformer was dead before hand so I tried charging it, and it wasn't charging, so I checked it and it seems the battery wire harness is loose enough to come off, is it possible to fix that?
christian cantu - Yanıt Paylaş
Hi christian! How did you solve this problem? That happened to me too...
Matheus Moraes - Yanıt Paylaş
what is the battery part # for t100 and can you purchase it?
thank you
RJ - Yanıt Paylaş
Part number is C12N1320. They are available from a variety of sources.
Jack Riggins - Yanıt Paylaş
Thanks for detailed guide.
I could not get the transformer tablet to power up no matter which buttons I held for how long or in what sequence. Unplugging the battery internally and replugging fixed a hung device.
JPWhite - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 43
Son 30 gün: 188
Her zaman: 133,378
