Ana içeriğe geç
Asus Transformer T100 Button Module Replacement
Neye ihtiyacın var
  1. Asus Transformer T100 Button Module Replacement, Rear Cover: adım 1, 2 resimden 1. Asus Transformer T100 Button Module Replacement, Rear Cover: adım 1, 2 resimden 2.
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
    FixBot'a Sor
    Yorum Ekle
  2. Asus Transformer T100 Button Module Replacement: adım 2, 2 resimden 1. Asus Transformer T100 Button Module Replacement: adım 2, 2 resimden 2.
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
    FixBot'a Sor
    Yorum Ekle
  3. Asus Transformer T100 Button Module Replacement: adım 3, 1 resimden 1.
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
    FixBot'a Sor
    Yorum Ekle
  4. Asus Transformer T100 Button Module Replacement: adım 4, 2 resimden 1. Asus Transformer T100 Button Module Replacement: adım 4, 2 resimden 2.
    • Remove the rear casing.
    FixBot'a Sor
    Yorum Ekle
  5. Asus Transformer T100 Button Module Replacement, Button Module: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Unclip the white connection clip using a pair of tweezers.
    FixBot'a Sor
    Yorum Ekle
  6. Asus Transformer T100 Button Module Replacement: adım 6, 2 resimden 1. Asus Transformer T100 Button Module Replacement: adım 6, 2 resimden 2.
    • Pull the connection apparatus from the connection clip on the board using a pair of tweezers.
    FixBot'a Sor
    Yorum Ekle
  7. Asus Transformer T100 Button Module Replacement: adım 7, 1 resimden 1.
    • Gently fold the connection apparatus back away from your work area.
    FixBot'a Sor
    Yorum Ekle
  8. Asus Transformer T100 Button Module Replacement: adım 8, 3 resimden 1. Asus Transformer T100 Button Module Replacement: adım 8, 3 resimden 2. Asus Transformer T100 Button Module Replacement: adım 8, 3 resimden 3.
    • Remove the screws using a Phillips Head #1 screwdriver.
    • Remove the power button module.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Taylor Pantiga
1.629 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-31, Maness Spring 2014 Cal Poly, Team 13-31, Maness Spring 2014 üyesi
CPSU-MANESS-S14S13G31
3 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
My problem is that when reinstalltng the back cover the button does not fit the button module to press the on/off switch. The switch works allright.
What can i do? At this moment I can only switch the tablet on after removing the back cover.
Rudolf Guys - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 56
Her zaman: 6,509
