Ana içeriğe geç
Asus Transformer T100 Front Facing Camera Board Replacement
Neye ihtiyacın var
  1. Asus Transformer T100 Front Facing Camera Board Replacement, Rear Cover: adım 1, 2 resimden 1. Asus Transformer T100 Front Facing Camera Board Replacement, Rear Cover: adım 1, 2 resimden 2.
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Front Facing Camera Board Replacement: adım 2, 2 resimden 1. Asus Transformer T100 Front Facing Camera Board Replacement: adım 2, 2 resimden 2.
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
  3. Asus Transformer T100 Front Facing Camera Board Replacement: adım 3, 1 resimden 1.
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Front Facing Camera Board Replacement: adım 4, 2 resimden 1. Asus Transformer T100 Front Facing Camera Board Replacement: adım 4, 2 resimden 2.
    • Remove the rear casing.
  5. Asus Transformer T100 Front Facing Camera Board Replacement, Front Facing Camera Board: adım 5, 1 resimden 1.
    • The camera board is located in the red square in this image.
  6. Asus Transformer T100 Front Facing Camera Board Replacement: adım 6, 2 resimden 1. Asus Transformer T100 Front Facing Camera Board Replacement: adım 6, 2 resimden 2.
    • Remove the two screws on the camera board using a Phillips #1 Screwdriver.
  7. Asus Transformer T100 Front Facing Camera Board Replacement: adım 7, 3 resimden 1. Asus Transformer T100 Front Facing Camera Board Replacement: adım 7, 3 resimden 2. Asus Transformer T100 Front Facing Camera Board Replacement: adım 7, 3 resimden 3.
    • Lift up the power button cable retention clip on the motherboard and pull the cable out.
  8. Asus Transformer T100 Front Facing Camera Board Replacement: adım 8, 2 resimden 1. Asus Transformer T100 Front Facing Camera Board Replacement: adım 8, 2 resimden 2.
    • On the camera connection apparatus, locate the silver tape that connects to the tablet.
    • Peel the silver tape off of the tablet on both sides of the connection apparatus.
    • If this step has been completed correctly, the camera board should be loose, with the tape still attached to the connection apparatus.
  9. Asus Transformer T100 Front Facing Camera Board Replacement: adım 9, 3 resimden 1. Asus Transformer T100 Front Facing Camera Board Replacement: adım 9, 3 resimden 2. Asus Transformer T100 Front Facing Camera Board Replacement: adım 9, 3 resimden 3.
    • Gently pull the Orange ribbon cable out of the connection port.
    • This port has no clip. The orange apparatus should slide out with a small tug.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Taylor Pantiga
1.617 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-31, Maness Spring 2014 Cal Poly, Team 13-31, Maness Spring 2014 üyesi
CPSU-MANESS-S14S13G31
3 Üyeler
1Rehber Yorum
Hello, can you please tell a manufacturer of the camera (is it writter somethere on it)?
Alexius Hoopakele Ae - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 30
Her zaman: 3,760
