Ana içeriğe geç
Asus U47VC-DS51 Cooling Fan Replacement
Neye ihtiyacın var
  1. Asus U47VC-DS51 Cooling Fan Replacement, Hard Drive: adım 1, 3 resimden 1. Asus U47VC-DS51 Cooling Fan Replacement, Hard Drive: adım 1, 3 resimden 2. Asus U47VC-DS51 Cooling Fan Replacement, Hard Drive: adım 1, 3 resimden 3.
    • Remove the hard drive cover.
    • Unscrew one 8mm Phillips #00 screw.
    • Using the black spudger, insert its flat end under the hard drive's covering, working around to pry it off.
  2. Asus U47VC-DS51 Cooling Fan Replacement: adım 2, 3 resimden 1. Asus U47VC-DS51 Cooling Fan Replacement: adım 2, 3 resimden 2. Asus U47VC-DS51 Cooling Fan Replacement: adım 2, 3 resimden 3.
    • Remove the hard drive.
    • Unscrew the four 3mm Phillips #00 screws.
    • Pull the hard drive's black tab away from the laptop to free it.
  3. Asus U47VC-DS51 Cooling Fan Replacement, Keyboard: adım 3, 2 resimden 1. Asus U47VC-DS51 Cooling Fan Replacement, Keyboard: adım 3, 2 resimden 2.
    • Remove 9 screws from bottom of notebook using PH00 bit + 1 under hard drive bay.
    • Remove 3 screws from bottom of notebook using PH00 bit. 1 is same screw spec as the other 9, and 2 are shorter.
  4. Asus U47VC-DS51 Cooling Fan Replacement: adım 4, 2 resimden 1. Asus U47VC-DS51 Cooling Fan Replacement: adım 4, 2 resimden 2.
    • Using the black spudger, insert its flat end between the crevice where the color changes from grey to black.
    • The keyboard is very tightly secured.
    • Carefully ease the spudger's end along the crevice, going around the entire frame.
    • The back connectors are short, so be careful when lifting.
  5. Asus U47VC-DS51 Cooling Fan Replacement: adım 5, 2 resimden 1. Asus U47VC-DS51 Cooling Fan Replacement: adım 5, 2 resimden 2.
    • Lift the keyboard from the front where it is closest to the screen.
    • Disconnect the large and small ZIF connectors attached to the motherboard by flipping the light-colored part of the switch.
  6. Asus U47VC-DS51 Cooling Fan Replacement: adım 6, 2 resimden 1. Asus U47VC-DS51 Cooling Fan Replacement: adım 6, 2 resimden 2.
    • Remove the third and last ZIF connector on the motherboard by flipping up the dark-colored part of the switch.
    • Now, the component should come completely free.
  7. Asus U47VC-DS51 Cooling Fan Replacement, Motherboard: adım 7, 3 resimden 1. Asus U47VC-DS51 Cooling Fan Replacement, Motherboard: adım 7, 3 resimden 2. Asus U47VC-DS51 Cooling Fan Replacement, Motherboard: adım 7, 3 resimden 3.
    • Unscrew the one 8mm screw using a Phillips #00.
    • Using the black spudger, slightly pry up on the tab and gently pull the optical drive away from the laptop in order to remove it.
  8. Asus U47VC-DS51 Cooling Fan Replacement: adım 8, 3 resimden 1. Asus U47VC-DS51 Cooling Fan Replacement: adım 8, 3 resimden 2. Asus U47VC-DS51 Cooling Fan Replacement: adım 8, 3 resimden 3.
    • Using the black spudger, slowly lift up on the cable connectors and pull them away from the connectors.
    • Repeat steps on both cables.
    • Unscrew the 12 8mm screws using a Phillips #00 screwdriver.
  9. Asus U47VC-DS51 Cooling Fan Replacement: adım 9, 3 resimden 1. Asus U47VC-DS51 Cooling Fan Replacement: adım 9, 3 resimden 2. Asus U47VC-DS51 Cooling Fan Replacement: adım 9, 3 resimden 3.
    • Lift up on the motherboard and disengage the two connectors.
    • Disconnect the cooling fan connector.
    • Unscrew the 7 8mm screws holding in the cooling fan using a Phillips #00 screwdriver.
  10. Asus U47VC-DS51 Cooling Fan Replacement, Cooling fan: adım 10, 3 resimden 1. Asus U47VC-DS51 Cooling Fan Replacement, Cooling fan: adım 10, 3 resimden 2. Asus U47VC-DS51 Cooling Fan Replacement, Cooling fan: adım 10, 3 resimden 3.
    • Use a Phillips screwdriver to loosen the four screws holding the component in place.
  11. Asus U47VC-DS51 Cooling Fan Replacement: adım 11, 1 resimden 1.
    • After loosening the screws, use the black spudger to help disconnect the fan wires from the connector.
  12. Asus U47VC-DS51 Cooling Fan Replacement: adım 12, 1 resimden 1.
    • The fan should then come free.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 548
