Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn the laptop over so the bottom is facing up.
Slide the two tabs on the bottom of the laptop toward the edges of laptop.
Slide the left tab to the left to lock it into the unlocked position. The red showing next to the tab signifies that it's unlocked.
Hold down the tab on the right side, then begin sliding the battery out.
Remove the old battery.
Remove the six screws using a Phillips #1 screwdriver.
Pry the lower panel up with your fingernail or a spudger.
Remove the two screws using a Phillips #1 screwdriver.
Using your finger, push the hard drive back.
Pry up the drive with an opening tool (or your fingernail).
Pull back on the hard drive and lift upwards.
Remove the component completely.
Use the plastic opening tool to push the drive out from the back.
Insert one of the pry tools under a top corner and the other tool under the side of the same corner. Make sure to get under the metal of the keyboard, not just the first layer of plastic. Then pry the corner down and out from under the little overhang its sitting under.
Next, slide the pry tool on the top over to the next overhang and insert the second tool on the other side. Push down and pry out the keyboard.
Repeat the same process all the way down to the opposite corner.
Once the keyboard is free, lift it up slightly and release the cable connection underneath.
Last, remove the keyboard completely from the computer.
Push back on the silver clips shown in the picture until you hear/feel a pop.
Pull back on the RAM card and remove it.
Repeat for the lower RAM card.
Remove the six screws from the outer lower case.
Remove the four screws from the hinges.
Remove the three screws on the inner lower case.
Remove the three screws from the optical drive area.
Pull the two bundled cables away from the connector in the same direction as the individual wires are running.
Pull the no-fuss ribbon cable straight out of the connector.
Pull the single bundled cable away from the connector in the same direction as the individual wires are running.
Pull the cable away from the connector in the same direction as the individual wires.
