Ana içeriğe geç
Asus U56E-BBL6 Motherboard Replacement
Neye ihtiyacın var
  1. Asus U56E-BBL6 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure you unplugged the laptop before you begin the replacement process.
    • Locate the battery locking tabs on the upper right and left corner.
    • Press the tabs in towards each other.
  2. Asus U56E-BBL6 Motherboard Replacement: adım 2, 1 resimden 1.
    • Pull the battery outwards to remove it.
  3. Asus U56E-BBL6 Motherboard Replacement, Back Panel: adım 3, 2 resimden 1. Asus U56E-BBL6 Motherboard Replacement, Back Panel: adım 3, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the screws.
  4. Asus U56E-BBL6 Motherboard Replacement: adım 4, 1 resimden 1.
    • Lift backplate and remove from the case.
  5. Asus U56E-BBL6 Motherboard Replacement, RAM: adım 5, 1 resimden 1.
    • Once inside the panel, locate your RAM sticks.
  6. Asus U56E-BBL6 Motherboard Replacement: adım 6, 2 resimden 1. Asus U56E-BBL6 Motherboard Replacement: adım 6, 2 resimden 2.
    • This device is embedded with two RAM sticks.
    • Push the metal brackets carefully to release and remove the RAM stick .
  7. Asus U56E-BBL6 Motherboard Replacement: adım 7, 2 resimden 1. Asus U56E-BBL6 Motherboard Replacement: adım 7, 2 resimden 2.
    • Repeat the previous step for removing the other RAM stick.
  8. Asus U56E-BBL6 Motherboard Replacement, Keyboard: adım 8, 1 resimden 1.
    • Using a Phillips #00, remove the four screws.
  9. Asus U56E-BBL6 Motherboard Replacement: adım 9, 2 resimden 1. Asus U56E-BBL6 Motherboard Replacement: adım 9, 2 resimden 2.
  10. Asus U56E-BBL6 Motherboard Replacement: adım 10, 1 resimden 1.
    • Use a plastic opening tool around the entire edge.
    • Separate the case from the keyboard.
  11. Asus U56E-BBL6 Motherboard Replacement: adım 11, 1 resimden 1.
    • Ensure the laptop is face up for this step.
    • Gently lift the keyboard from the base of the laptop.
    • Be careful of the ribbon cables connecting the keyboard.
  12. Asus U56E-BBL6 Motherboard Replacement: adım 12, 1 resimden 1.
    • Gently tug the ribbon cables free from their slots.
  13. Asus U56E-BBL6 Motherboard Replacement: adım 13, 2 resimden 1. Asus U56E-BBL6 Motherboard Replacement: adım 13, 2 resimden 2.
    • Using both hands, pull the keyboard back and out, fully separating the keyboard from the laptop.
  14. Asus U56E-BBL6 Motherboard Replacement, Optical Drive: adım 14, 1 resimden 1.
    • Using a plastic opening tool, separate the optical drive from the laptop frame.
    • Be careful to leverage the plastic opening tool against the frame and not the motherboard as this may cause damage.
  15. Asus U56E-BBL6 Motherboard Replacement: adım 15, 1 resimden 1.
    • Remove the optical drive by sliding it out from the case.
  16. Asus U56E-BBL6 Motherboard Replacement, Motherboard: adım 16, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the three screws.
  17. Asus U56E-BBL6 Motherboard Replacement: adım 17, 3 resimden 1. Asus U56E-BBL6 Motherboard Replacement: adım 17, 3 resimden 2. Asus U56E-BBL6 Motherboard Replacement: adım 17, 3 resimden 3.
    • Lift up the ribbon cable connector on the bottom right corner.
    • Gently pry the cable away from the connection.
  18. Asus U56E-BBL6 Motherboard Replacement: adım 18, 2 resimden 1. Asus U56E-BBL6 Motherboard Replacement: adım 18, 2 resimden 2.
    • Remove the 4 pronged connection on the bottom right corner of the motherboard.
  19. Asus U56E-BBL6 Motherboard Replacement: adım 19, 2 resimden 1. Asus U56E-BBL6 Motherboard Replacement: adım 19, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the two screws.
    • Holding the board firmly with two fingers, pull outward, disconnecting it from the contacts.
  20. Asus U56E-BBL6 Motherboard Replacement: adım 20, 1 resimden 1.
    • Repeat the previous step and remove the two wired connection next to the card.
  21. Asus U56E-BBL6 Motherboard Replacement: adım 21, 2 resimden 1. Asus U56E-BBL6 Motherboard Replacement: adım 21, 2 resimden 2.
    • Remove the cable at the top left of the motherboard.
    • This cable is held in by a magnetic connection. Be sure to lift up and away when disconnecting.
  22. Asus U56E-BBL6 Motherboard Replacement: adım 22, 2 resimden 1. Asus U56E-BBL6 Motherboard Replacement: adım 22, 2 resimden 2.
    • Using both hands, lift the motherboard up and out from the case
Sonuç
Bir başkası bu kılavuzu tamamladı.
Josiah Allard
733 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G8, Peak Fall 2018 UMass Dartmouth, Team S2-G8, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S2G8
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 611
