Ana içeriğe geç
Asus UL30VT-X1 Ram Replacement
Neye ihtiyacın var
  1. Asus UL30VT-X1 Ram Replacement, Ram: adım 1, 2 resimden 1. Asus UL30VT-X1 Ram Replacement, Ram: adım 1, 2 resimden 2.
    • Flip the laptop over onto the back.
  2. Asus UL30VT-X1 Ram Replacement: adım 2, 1 resimden 1.
    • Locate the two screws on the ram panel.
    • Unscrew the two screws using a Phillips Head #00 screwdriver.
  3. Asus UL30VT-X1 Ram Replacement: adım 3, 1 resimden 1.
    • Locate the small cut out at the bottom of the ram panel.
    • Lift the rem panel up with your finger and remove it to expose the ram.
  4. Asus UL30VT-X1 Ram Replacement: adım 4, 2 resimden 1. Asus UL30VT-X1 Ram Replacement: adım 4, 2 resimden 2.
    • locate the white clips on the sides of the ram.
    • Push the white clips to the side so the ram pops out
    • Afterword use your fingers to pull the ram towards you.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 190
