Ana içeriğe geç
Asus UL80VT Motherboard Replacement
Neye ihtiyacın var
  1. Asus UL80VT Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop so you can see the back side.
  2. Asus UL80VT Motherboard Replacement: adım 2, 2 resimden 1. Asus UL80VT Motherboard Replacement: adım 2, 2 resimden 2.
    • Identify the two slide locks below the battery. Slide them outward towards the unlock symbol. You should see a red mark that indicates that the battery is unlocked and is ready for removal.
  3. Asus UL80VT Motherboard Replacement: adım 3, 1 resimden 1.
    • Now you can remove the battery while continuing to hold the right battery lock in the unlock position.
  4. Asus UL80VT Motherboard Replacement, Hard Drive: adım 4, 3 resimden 1. Asus UL80VT Motherboard Replacement, Hard Drive: adım 4, 3 resimden 2. Asus UL80VT Motherboard Replacement, Hard Drive: adım 4, 3 resimden 3.
    • Flip the computer over, and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
    • Lift the panel from the device.
  5. Asus UL80VT Motherboard Replacement: adım 5, 2 resimden 1. Asus UL80VT Motherboard Replacement: adım 5, 2 resimden 2.
    • Slide the hard drive away from the SATA connector and remove the hard drive from the device.
  6. Asus UL80VT Motherboard Replacement, RAM: adım 6, 1 resimden 1.
    • Flip computer over and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
  7. Asus UL80VT Motherboard Replacement: adım 7, 3 resimden 1. Asus UL80VT Motherboard Replacement: adım 7, 3 resimden 2. Asus UL80VT Motherboard Replacement: adım 7, 3 resimden 3.
    • Pull the clips toward the chassis of the computer. The RAM will pop up and can easily be removed.
  8. Asus UL80VT Motherboard Replacement, Keyboard: adım 8, 2 resimden 1. Asus UL80VT Motherboard Replacement, Keyboard: adım 8, 2 resimden 2.
    • Open laptop so the keyboard is accessible.
    • Insert a plastic prying tool and push and then pull to release the keyboard from the device.
  9. Asus UL80VT Motherboard Replacement: adım 9, 1 resimden 1.
    • Lift keyboard and remove ZIF connector cables.
    • Remove the keyboard from the device.
  10. Asus UL80VT Motherboard Replacement, Motherboard: adım 10, 1 resimden 1.
    • Remove the nine 5 mm screws using the Phillips #0 screwdriver.
  11. Asus UL80VT Motherboard Replacement: adım 11, 1 resimden 1.
    • Flip the laptop over and remove nine 5 mm screws using the Phillips #0 screwdriver.
  12. Asus UL80VT Motherboard Replacement: adım 12, 2 resimden 1. Asus UL80VT Motherboard Replacement: adım 12, 2 resimden 2.
    • Use the iFixit opening tool to remove the cd drive on the left of the laptop.
  13. Asus UL80VT Motherboard Replacement: adım 13, 1 resimden 1.
    • Use the same tool to remove the plastic top from the laptop.
  14. Asus UL80VT Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove the eight 3 mm screws using the Phillips #0 screwdriver.
    • Lift up the motherboard and disconnect all wires attaching the motherboard to the rest of the computer.
  15. Asus UL80VT Motherboard Replacement: adım 15, 1 resimden 1.
    • Lift the motherboard out of the laptop and remove it from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
James DellaMorte
660 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G5, Botvin Spring 2019 UMass Dartmouth, Team S1-G5, Botvin Spring 2019 üyesi
UMASSD-BOTVIN-S19S1G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 434
