Giriş
The motherboard is your machine's main control center, where processing occurs. If your motherboard is broken, you absolutely will have to swap it. This tutorial will demonstrate how the motherboard can be replaced.
Neye ihtiyacın var
Flip the computer over, and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
Lift the panel from the device.
Flip computer over and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
Open laptop so the keyboard is accessible.
Insert a plastic prying tool and push and then pull to release the keyboard from the device.
2 farklı kişi bu kılavuzu tamamladı.
