Ana içeriğe geç
Asus V500CA-DB51T Hard Drive Replacement
Neye ihtiyacın var
  1. Asus V500CA-DB51T Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Asus V500CA-DB51T Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • The top left and right corners have .7 cm screws.
    • The two top-middle and four bottom are .4 cm screws.
    • The middle left and right are .8 cm screws.
    • Remove the screws using the Phillips #00 screwdriver.
  2. Asus V500CA-DB51T Hard Drive Replacement: adım 2, 2 resimden 1. Asus V500CA-DB51T Hard Drive Replacement: adım 2, 2 resimden 2.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. Asus V500CA-DB51T Hard Drive Replacement: adım 3, 1 resimden 1.
    • Use the flat end of the blue plastic opening tool to lift the battery connector up out of its socket on the motherboard.
  4. Asus V500CA-DB51T Hard Drive Replacement: adım 4, 2 resimden 1. Asus V500CA-DB51T Hard Drive Replacement: adım 4, 2 resimden 2.
    • Remove the tri-point screws that secure the battery to the casing.
    • All screws securing the battery in place are .5 cm tri-point screws.
  5. Asus V500CA-DB51T Hard Drive Replacement: adım 5, 3 resimden 1. Asus V500CA-DB51T Hard Drive Replacement: adım 5, 3 resimden 2. Asus V500CA-DB51T Hard Drive Replacement: adım 5, 3 resimden 3.
    • Use the opening tool to pop up the battery away from the casing.
  6. Asus V500CA-DB51T Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 1. Asus V500CA-DB51T Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 2. Asus V500CA-DB51T Hard Drive Replacement, Hard Drive: adım 6, 3 resimden 3.
    • Remove the following screws securing the battery connector board to the logic board:
    • The red screws are size 2.3 cm T6 Torx
    • The orange screws are size 2.4 cm T6 Torx
  7. Asus V500CA-DB51T Hard Drive Replacement: adım 7, 2 resimden 1. Asus V500CA-DB51T Hard Drive Replacement: adım 7, 2 resimden 2.
    • Remove the SSD (Solid State Drive) assembly from the upper case.
Sonuç
Galen P Garofalo
670 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G2, Rockett Fall 2017 UMass Dartmouth, Team S6-G2, Rockett Fall 2017 üyesi
UMASSD-ROCKETT-F17S6G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 566
