Ana içeriğe geç
Asus V6800V CD/DVD Drive Replacement
Neye ihtiyacın var
  1. Asus V6800V CD/DVD Drive Replacement, Battery: adım 1, 2 resimden 1. Asus V6800V CD/DVD Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V CD/DVD Drive Replacement, Hard Drive: adım 2, 2 resimden 1. Asus V6800V CD/DVD Drive Replacement, Hard Drive: adım 2, 2 resimden 2.
    • Remove the two screws using a Phillips #0 screwdriver.
  3. Asus V6800V CD/DVD Drive Replacement: adım 3, 2 resimden 1. Asus V6800V CD/DVD Drive Replacement: adım 3, 2 resimden 2.
    • Pry open the case using an iFixit opening tool.
    • Actual hard drive is not shown in the second image.
  4. Asus V6800V CD/DVD Drive Replacement: adım 4, 2 resimden 1. Asus V6800V CD/DVD Drive Replacement: adım 4, 2 resimden 2.
    • The highlighted area is where your hard drive would be. Slide it out away from its slot and pull it gently to remove.
    • Second image shows what it should look like once you remove the hard drive.
  5. Asus V6800V CD/DVD Drive Replacement, CD/DVD Drive: adım 5, 2 resimden 1. Asus V6800V CD/DVD Drive Replacement, CD/DVD Drive: adım 5, 2 resimden 2.
    • Remove the screw from the bottom right corner using a Phillips #0 screwdriver.
    • Insert a spudger into the hole to carefully push the CD/DVD drive out.
Sonuç
To reassemble your device, just push the new CD/DVD driver back. Then put the components back together then put the screws back in.
Jong Park
114 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S2G9
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 4,292
