Ana içeriğe geç
Asus V6800V Fan Replacement
Neye ihtiyacın var
  1. Asus V6800V Fan Replacement, Battery: adım 1, 2 resimden 1. Asus V6800V Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Fan Replacement, Fan: adım 2, 2 resimden 1. Asus V6800V Fan Replacement, Fan: adım 2, 2 resimden 2.
    • Use the Phillips #0 to remove the six screws on the back of the device.
    • Gently open the cover using the tab located by the highlighted box.
  3. Asus V6800V Fan Replacement: adım 3, 2 resimden 1. Asus V6800V Fan Replacement: adım 3, 2 resimden 2.
    • Unplug the wires by pulling straight up on the white connector and away from the computer.
    • Make sure not to pull on the wires (as shown in the second picture). The white connector should pop off with very little force.
  4. Asus V6800V Fan Replacement: adım 4, 2 resimden 1. Asus V6800V Fan Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #0 to remove the three screws holding the fan in place.
  5. Asus V6800V Fan Replacement: adım 5, 2 resimden 1. Asus V6800V Fan Replacement: adım 5, 2 resimden 2.
    • Remove the fan from the device.
    • The fan should remove easily.
  6. Asus V6800V Fan Replacement: adım 6, 2 resimden 1. Asus V6800V Fan Replacement: adım 6, 2 resimden 2.
    • Use a cotton swab or compressed air to blow air from the inside, out to clear dust from the vent or heat sink.
Sonuç
Jong Park
114 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S2G9
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 4,992
